External power pack - R66
stuartto
Engine Cranking
Unread post by stuartto » Mon Jul 01, 2019 1:51 pm
Am looking at options to keep in our hangar.
Budget option is two 12V batteries and the connector plug - any idea who supplies this plug to the local Heli trade?
Thanks
Tim
Has liked: 53 times
Been liked: 28 times
Re: External power pack - R66
Unread post by Tim » Mon Jul 01, 2019 2:26 pm
Thanks
Try your AMO for the MS 3506 female plug. Also, aviation supply suppliers like Spruce should have it. Belaire Aviation at OR Tambo can import Spruce items for you.
These users liked the author Tim for the post:
stuartto
Arch
Has liked: 39 times
Been liked: 31 times
Unread post by Arch » Mon Jul 01, 2019 9:43 pm
Thanks
https://www.redboxaviation.com/product- ... wer-units/
If you're taking about truck batteries, that's not the budget option - they boil spectacularly when used on a chopper. Check the link above for dedicated gpu options, but they're not cheap. The start up amps required for a gas turbines by far exceeds the current delivery capability of lead-based batteries.
DipStick
Unread post by DipStick » Mon Jul 01, 2019 9:54 pm
We used to use 2 truck batteries to dry motor a Cessna caravan, never had any issues. But they might not last as long compared to them being used in trucks.
Aidan J Mills
ATPL
L410
PC12
C208
PA34
Aviate, Aviate, Aviate, Navigate, Communicate
Look outside, lest you miss the main event!
Bront
Taxiing
Closest Airfield: fact
Been liked: 29 times
Unread post by Bront » Tue Jul 02, 2019 2:25 am
Thanks
Really? Been using car and truck batteries to start helicopters for over 30 years and never had a problem. Charge them properly, keep the electrolyte topped up and they will last years.
Arch
Has liked: 39 times
Unread post by Arch » Tue Jul 02, 2019 6:42 am
Thanks
A mate fried a farmer's truck batteries starting a jetty, and I cooked two brand new 24v 100ah (parallel connection) batteries starting a squirrel. It's all about the C rating of the battery, and most lead acids aren't designed to dump that much current in such a short space of time. Anyway, the battery supplier will be able to match the correct C rated unit. My point is, it's not just about hooking up to batteries in series to get 24v
Has liked: 634 times
Been liked: 556 times
Unread post by Ugly Duckling » Tue Jul 02, 2019 7:01 am
I designed and manufactured the sealed lead acid batteries for the Puma, Alouettes, F1, Mirage III, Cheetah, Oryx, Astra/PC7 Mk2 and the KwikStart range of battery GPUs.
I have sent Stuart a PM.
These users liked the author Ugly Duckling for the post (total 2):
ArchCornell Blok
Bront
Taxiing
Unread post by Bront » Wed Jul 03, 2019 2:50 am
I'm not sure how you managed to do that? The most primitive setup I've ever used was 2 small car batteries connected together with a piece of fencing wire just wrapped around the terminals and a set of jumper leads to the aircraft and that was on a Jetty!!!
Of course if you are going to make up a dedicated starter pack then you should get decent, heavy duty, deep cycle batteries, not just any old thing. But nearly every operator I've ever worked for had a set of 2 decent truck batteries as their battery cart. Buying expensive aircraft specific battery banks just doesn't make sense IMHO. Sure a portable aircraft battery pack is a great idea if you want to carry it with you in the aircraft when going to remote locations but for your home base, no way.
stuartto
Engine Cranking
Unread post by stuartto » Tue Jan 07, 2020 11:10 am
To close the loop on this thread I started last year:
To anyone going down the route of an external power pack, Ugky Duckling helped me with two units - a very elegant solution for external power. And comforting to know as we are heli users so land in some distant places!
Unread post by Ugly Duckling » Tue Jan 07, 2020 11:23 am
Thanks for the feedback Stuart.
APR Africa is pleased that you are getting the performance that you desired.
Excuse me for posting pictures of our Easi-Start units.
Return to “Rotor Wing”
