Hi Everyone
I am busy doing some homework and number crunching on a R44 Raven II rebuild , Has anyone recently done one as I have a couple questions and would like to pick their brain please.
Thank You
RH 44 12Yr Rebuild
- Frequent AvComer
- Closest Airfield: FAWB
- Has liked: 72 times
- Been liked: 2 times
Re: RH 44 12Yr Rebuild
Hi Bleu,
Here is a very intriguing thread about just that!
ZS-RUT was rebuilt by tanglefoot and co. and he really did a good job of keeping us desk jockeys informed - loved it. Hopefully you will do the same.
Craig.
Craig.
Skill and luck - always have enough of both
- Aircraft in Hangar
- Closest Airfield: Private
- Has liked: 0
- Been liked: 0
Thank you so much will have a squizz over that.
Thanks again
Thanks again
csparksfly wrote: ↑Tue Oct 22, 2019 7:50 amHi Bleu,
Craig.
- Take off Clearance
- Closest Airfield: Virginia FAVG
- Has liked: 1 time
- Been liked: 0
The guys from Acher Aviation is currently rebuilding the R44 for JNC Helicopters down here in Durban - maybe they can also answer some questions...
Don't worry, I'm from the QUARRY...
- Flying to unmanned aerodrome
- Closest Airfield: FAGC
- Has liked: 22 times
- Been liked: 7 times
There is a “12-yr inspection”, and a “2200 HR overhaul”. They are not the same, and the cost is very different.csparksfly wrote: ↑Tue Oct 22, 2019 7:50 amHi Bleu,
Craig.
I believe Tanglefoot did the 2200 overhaul, commonly referred to as “rebuild”. Arguably, the term “12-yr rebuild” is therefore a misnomer.
There should be a number of people on this Forum who know how this works. What do you want to know?
- These users liked the author Tim for the post (total 2):
- Pete • csparksfly
- Tripped over wheel chock
- Closest Airfield: Jack Taylor
- Has liked: 0
- Been liked: 0
Speak to Reyno or Vaughn at Aircraft Incorporated @ FAKR ( Jack Taylor ), they are a Robbie overhaul and rebuild center and do so good work!!Tim wrote: ↑Thu Oct 24, 2019 9:22 pmThere is a “12-yr inspection”, and a “2200 HR overhaul”. They are not the same, and the cost is very different.csparksfly wrote: ↑Tue Oct 22, 2019 7:50 amHi Bleu,
Craig.
PM me for their details
