Affordable jets, Kero, EDF and propeller craft!!!
RCSA is a web based RC product supplier including apparel. Also contact us to assist with a possible import from products not represented in SA. We can also assist with guidance and getting you of the ground if you are new to RC flying. Our Web: https://rcsa.org.za/
Moderator: RCSA
RCSA
Commercial Supporter
Unread post by RCSA » Thu Nov 29, 2018 12:58 pm
It is with great pleasure that we announce that RCSA are now the sole agents for HSD products. HSD is known for their new Foam RC Jets. These are strong and runs on a Kero turbine just like any other jet. The Mirage2000 is just under 2m long! So don't let the word Foam mislead you. This new approach makes for a 2m jet, complete with lights, electric gear, breaks, etc for just over R21k (excl.), all you need is a turbine n the range of 6 to 7kg (batteries and RC also). We are busy adding Foam Jets, EDF jets, Foam propeller craft and accessories!
Check the product range on https://rcsa.org.za/ and follow us on https://www.facebook.com/RCSA-352839991917104 as we plan a opening/stocking promotion.
Return to “RCSA”
