Jabbi Jack
wdpl
Priming
Closest Airfield: Kitty Hawk
Jabbi Jack
Unread post by wdpl » Tue Jan 26, 2016 11:23 am
Hi.
Can anyone please post me a picture of the Jabbi Jack.
Wikus du Plessis
pietmeyer
Been liked: 23 times
Re: Jabbi Jack
Unread post by pietmeyer » Tue Jan 26, 2016 12:35 pm
For my Jabi when having to chnage tyres I use a cheap scissor jack. Work like a charm
ZU-DUU Jabi J400 (FAWB)
Marius Schrenk
Has liked: 165 times
Been liked: 96 times
Re: Jabbi Jack
Unread post by Marius Schrenk » Tue Jan 26, 2016 4:50 pm
pietmeyer wrote:For my Jabi when having to chnage tyres I use a cheap scissor jack. Work like a charm
Piet die ding is effe swaar vir ons vetgatte om saam te vlieg. Die Jab jack het n paar tweaks nodig....die undercarriage leg het n manier om na buite uit te wyk net as die wiel die grond verlaat......dan donner hy af. :twisted:
pietmeyer
Re: Jabbi Jack
Unread post by pietmeyer » Tue Jan 26, 2016 9:35 pm
Marius
Ek dink ek het dalk verkeerde naam genoem. Die jack wat ek gebruik is klein en lig. Hy pas mooi onder maar mens moet net versigtig dat hy nie af donner nie. Dit is ook een van die goedkoopste jacks. Sal n foto post as ek weer by die hangar is
Has liked: 16 times
Been liked: 335 times
Re: Jabbi Jack
Unread post by cage » Tue Jan 26, 2016 10:27 pm
Stupid question.. For something that weighs the same as a microwave egg-poacher why do you need a jack?
Can't vroutjie just lift the wing so the tyre can be changed? ;)
Swampdonkey
Has liked: 17 times
Re: Jabbi Jack
Unread post by Swampdonkey » Tue Jan 26, 2016 11:09 pm
cage wrote:Stupid question.. For something that weighs the same as a microwave egg-poacher why do you need a jack?
Scissor jacks are quieter. :wink: :wink:
Has liked: 16 times
Re: Jabbi Jack
Unread post by cage » Wed Jan 27, 2016 9:09 am
:lol: good one
Marius Schrenk
Re: Jabbi Jack
Unread post by Marius Schrenk » Wed Jan 27, 2016 12:26 pm
That it exactly what the POH say. :D but they somehow get tired after a wile......and the tall one's are very expensive. :roll:
Swampdonkey
Has liked: 17 times
Re: Jabbi Jack
Unread post by Swampdonkey » Thu Jan 28, 2016 10:13 am
SO HOW ABOUT A PICTURE OF THE JABBI JACK!
ZuluBen
Re: Jabbi Jack
Unread post by ZuluBen » Thu Jan 28, 2016 2:00 pm
Fanie from Rustenburg (Garfield here on Avcom) got his dad to make us great jacks.
A cheap hydraulic bottle jack (Midas) to which he has welded an attachment that grips the landing gear just lekker and hold it well in place. One of my treasured tools in the hanger.
Oh yes, and it is quiet as well 8) :wink: :lol:
Will take a pic when I get to the hanger over the weekend.
wdpl
Priming
Re: Jabbi Jack
Unread post by wdpl » Thu Jan 28, 2016 2:29 pm
Dankie Ben
Maybe I can get a couple made by my do it all friend if any body interested.
bluboyz
Preflighting
Closest Airfield: YMAY
Re: Jabbi Jack
Unread post by bluboyz » Mon Feb 01, 2016 2:36 am
On this UK Jab builder site:~ http://www.jabiruowner.co.uk/jabtip.html There is a simple, lightweight, and portable jack kit solution.. Andy Hollitt posted:~ This is a simple screwjack built around a 75mm high tensile 10mm bolt, running in a piece of chrom moly tube with top and bottom shoulders welded on. A saddle welded to the head of the bolt fits under the undercarriage leg. Turn the nut and up goes the Jabi! Photo:~ http://www.jabiruowner.co.uk/pict3.jpg
On:~ http://www.recreationalflying.com/threa ... 257/page-1 there is scissor jack example ... Andys@coffs posted:~ The top bit uses the narrowing of the undercarriage leg as it goes down to the wheel to allow an interference fit for lift. Inside the welded shape is carpet to stop leg scratching (Note that in the 1st photo the scissor base is probably at 90 degrees to that shown) photos as shown:~
http://www.recreationalflying.com/attac ... -jpg.2243/
http://www.recreationalflying.com/attac ... -jpg.2245/
http://www.recreationalflying.com/attac ... -jpg.2244/
jetjr
Re: Jabbi Jack
Unread post by jetjr » Tue Feb 02, 2016 10:33 pm
Make sure whatever you use can get under the leg WITH a flat tyre.
