Bing carb rebuild
buffet
Closest Airfield: east london
Bing carb rebuild
Unread post by buffet » Tue Apr 12, 2016 2:14 pm
Hi Gents do anyone know who can rebuild my Jabi carb?
Besides the factory.
ZuluBen
Re: Bing carb rebuild
Unread post by ZuluBen » Tue Apr 12, 2016 4:48 pm
Really simple.
Get the Carb Kit from the factory.
Add new Needle and Seat to the list.
A new float if you really want to...
Strip fully, soak in Carb Cleaner.
Blow all passages out with an Air duster and compressor.
Reassemble with the manual next to you... 8)
Get to the plane, connect fuel, use electric pump to fill, check float level, and if required adjust and repeat.
buffet
Unread post by buffet » Wed Apr 13, 2016 7:41 am
Thank you :wink:
