Take off distance in j4xx
TonyL
Closest Airfield: FAEL
Re: Take off distance in j4xx
Unread post by TonyL » Thu Nov 29, 2018 9:41 pm
Hi Ben
Would it be a major task to extend the data to reflect the MAUW to be 800kg? This would then provide info for the new J430's which now have an increased MAUW of 800kg.
Tks
Tony
BigglesSA
Has liked: 19 times
Unread post by BigglesSA » Fri Nov 30, 2018 7:48 am
Hi Tony
760kg or 800kg? I am not aware of a change to 800kg. It was 700kg with an increase to 760kg.
Groetnis
Francois Gouws
TonyL
Unread post by TonyL » Fri Nov 30, 2018 7:51 am
Hi
The latest is 800kg (I know, I am about to take delivery of a new one :D ). This is a recent change which happened during the course of this year.
Tony
Hi Tony
BigglesSA
Has liked: 19 times
Unread post by BigglesSA » Fri Nov 30, 2018 8:04 am
My my! I AM falling behind :shock: :roll:
Groetnis
Francois Gouws
Biltong
Climbing Out
Has liked: 31 times
Unread post by Biltong » Fri Nov 30, 2018 8:33 am
Hi Tony
Congrats.
What will the empty weight be?
Hi
Tony
Hi Tony
If you fail to plan, you are planning to fail! BA Baracus
TonyL
Unread post by TonyL » Fri Nov 30, 2018 8:37 am
She was weighed on Wednesday and came in at 396kg. First test flight was that afternoon and all went well. I haven't spilled the beans on the new plane or build on the forum yet. Will wait to take delivery and will then post pictures, etc. on the Jabiru group.
Tony
Hi Tony
Congrats.
TonyL
Unread post by TonyL » Fri Nov 30, 2018 8:48 am
I was pleasantly surprised too!
sadave
Closest Airfield: FAQT
Unread post by sadave » Sat Dec 01, 2018 6:40 am
Hi Tony,
Has the paper work come through from Aus? The last I heard (~2 months ago) they were still waiting for final papers although they are building to the 800kg spec for around 1 year now.
Dave
PS I bet you chomping at the bit to get your hands on her.
TonyL
Unread post by TonyL » Sat Dec 01, 2018 7:05 am
Hi Dave
I am presuming that it has. In fact I was not aware that there was an issue :? . I have seen the draft POH for my plane and it states 800kg MAUW. I hope that there isn't an issue as time is very tight wrt getting the ATF through the SACAA system in time to take delivery this year (I know optimistic, but very hopeful).
And yes, can't wait :D
Hi Tony,
Dave
sadave
Unread post by sadave » Sat Dec 01, 2018 7:16 am
Hi Dave
=D> =D> =D>
Awesome !!! It must have come through then, if POH has been updated. Was no real issue, Aus just had to sign off on the paper work but wanted the factory to do additional testing for COG limits, or something to that effect. Don't see an issue at SACAA, mine reflects as 800 on the register but I have been waiting for the POH to be updated.
TonyL
Unread post by TonyL » Sat Dec 01, 2018 7:49 am
:smt023 :smt023
=D> =D> =D>
