Jabiru Service Bulletins
FLIGHT_STICK
Re: Jabiru Service Bulletins
Unread post by FLIGHT_STICK » Fri Sep 13, 2013 7:32 pm
Gents
We picked up CYR today from George . My son did the handover flight and landed with a smile from ear to ear. Len thanks for doing an awesome job on CYR. The flight back to CT this afternoon was great she maintained 800/1000 ft in the climb till 8500 with full tanks and two big boys up front. Never seen EGT/ CHT so good before . UMMM OT sensor is not right :D :D
Thanks again see you all in 25 hrs for a checkup :D :) =D>
ZuluBen
Unread post by ZuluBen » Sat Sep 14, 2013 9:49 pm
Glad you got the worries sorted! :wink: =D>
A well set up 400 is an awesome cruiser. Now go stretch those legs 8)
Wingsoverafrica
Airborne from Unmanned field
Closest Airfield: Morningstar
Unread post by Wingsoverafrica » Mon Dec 08, 2014 8:26 am
Gents,
i would assume you all have seen this. Some interesting reading
Mogas
Flaps set for Take off
Unread post by Mogas » Mon Dec 08, 2014 10:30 am
Bla f$&/(n bla!
So what are they doing about CORRECTING the things going wrong?
As in, what replacement parts can we use to replace the inferior failing parts and still keep the Jab data plate that we bought with hard earned cash in good faith???
We already have a lot of experience in identifying the problems and don't need to be told how to look for them.
The excuses blaming the operators and maintainers are wearing very thin now.
It has become common to see even the best cooled and cared for engines fail routine blo-by tests at 200-300 hours.
As an AP I have to tell owners and operators that the top has to come off on a 100hr "service" and they are getting gatvol with good reason.
It is clear to me that this is Jab Aus's answer to the recent prod by CAASA but in my opinion the problem remains and they are just covering their arses with another bulletin.
Sippin mogas
wynand
Closest Airfield: FAHT
Been liked: 28 times
Unread post by wynand » Mon Dec 08, 2014 7:54 pm
I glanced through the SL. Seems quite sensible to me. I'll read in full tomorrow.
Wingsoverafrica
Unread post by Wingsoverafrica » Mon Dec 08, 2014 10:58 pm
wynand wrote:I glanced through the SL. Seems quite sensible to me. I'll read in full tomorrow.
Very sensible. I just hope the owners doing the assessment are honest with themselves and there AME. Good reading I think.
Has liked: 29 times
Been liked: 163 times
Unread post by heisan » Thu Jan 15, 2015 10:34 am
JSB 031-3 out today. Seems like we need to add some washers at the next 25 hour service...
Wingsoverafrica
Unread post by Wingsoverafrica » Thu Jan 15, 2015 2:37 pm
heisan wrote:JSB 031-3 out today. Seems like we need to add some washers at the next 25 hour service...
downloaded from where don't see it on the Jabi Site
Has liked: 29 times
Unread post by heisan » Thu Jan 15, 2015 3:04 pm
www.jabiru.net.au -> 'Service Bulletins'
http://jabiru.net.au/images/JSB031-3_Th ... pgrade.pdf
jetjr
Unread post by jetjr » Thu Jan 22, 2015 11:01 pm
If the engine is in the SN range. And used for training is a full tear down to replace studs
wynand
Unread post by wynand » Tue Jan 27, 2015 11:11 am
jetjr wrote:If the engine is in the SN range. And used for training is a full tear down to replace studs
Replacing studs and through-bolts is hardly an exercise that can be called a "full tear down".
Mine is done and dusted. I think it took about 3 hours.
Wingsoverafrica
Unread post by Wingsoverafrica » Tue Jan 27, 2015 11:34 am
Mine was done last year already and required line boring after...bummer....
singleton
Radio Call
Unread post by singleton » Tue Feb 03, 2015 9:49 am
Thanks guys for keeping me in the loop
LIGHT SPORT JABIRU INSTRUCTOR
BallsOfFire
Unread post by BallsOfFire » Sat May 23, 2015 7:20 am
My J160 engine packed up a few weeks back. It is at the factory and I went to have a look. A valve broke and with that the conrod twisted braking the piston etc.
Based on the SL Jabiru JSL014-1 that was not done by my AMO I now sit with this. There need to be a PROPER Jabiru AMO fasility, not a man in a van or someone doing this parttime.....
So guys I suggest you do this SL ASAP before you also in my situation.
The good thing for me js, I am getting a new blueprinted engine as a replacement....
Rgs
BoF
wynand
Unread post by wynand » Mon May 25, 2015 10:50 am
Argh! Sorry to hear about your woes, BoF.
I think JSL014-1 is a very sensible protocol, for any aero engine.
In my opinion it embodies what a competent AMO should be doing anyway. We say that when an engine tries to tell us something we should listen. JSL014-1 tells us HOW to listen.
