RV 8 first flight 30 Aug 13
Jakkels
Power off Glide
Re: RV 8 almost ready for test flight.
Unread post by Jakkels » Thu Sep 05, 2013 9:59 am
This is a very good example that a Lack of Snags is proportional to built quality !!! =D> =D> =D> =D>
Has liked: 576 times
Been liked: 174 times
Unread post by ACE MAN » Thu Sep 05, 2013 10:02 am
Mooi man !!!
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
ilikeadornier
Engine Cranking
Closest Airfield: Kitty Hawk
Unread post by ilikeadornier » Mon Sep 16, 2013 5:48 pm
ACE MAN wrote:Wrt your snag no1. Is this at cruise speed and is the tendency less or rolling to the right at low speed / glide speed?
This is at cruise speed and tendency becomes less at lower speed,rolling tendency remains to the left.
The aircraft is comfortably flyable in this state (full right aileron trim).We have decided to continue flying like this and will
Troubleshoot when the wheel spats and gear fairings are fitted.
ilikeadornier
Engine Cranking
Re: RV 8 first flight 30 Aug 13
Unread post by ilikeadornier » Mon Sep 16, 2013 5:57 pm
We did another 1.2 hours yesterday so the aircraft now has a total of 16.2 hrs.
Before yesterday's flight we did an oil and oil filter change and cleaned and re-oiled the air filter.
I personally think that the engine is now almost run in but we will fly it hard for a couple more hours just to make sure.
The EFIS behaved itself yesterday and did not bomb out like on previous flights but we are still researching this snag.
:D :D :D
sweptwing
Has liked: 43 times
Been liked: 16 times
Unread post by sweptwing » Tue Sep 17, 2013 9:05 pm
ilikeadornier wrote:We did another 1.2 hours yesterday so the aircraft now has a total of 16.2 hrs.
:D :D :D
a bear minimum of 25 hours full throttle in my opinion. :D
I know there's a lot of money in aviation because I put it there.
ilikeadornier
Engine Cranking
Unread post by ilikeadornier » Wed Oct 09, 2013 3:43 pm
The aircraft now has 21.3 hrs on it,and we still flying it balls to the wall.
Because we are using an uncertified engine, Lycoming YIO-360-M1B ,CAA wants 45hrs before applying for an authority to fly.
As far as i know the law says min 40hrs for an uncertified engine.
Our engine is uncertified but this rule should apply to an automotive conversion in my opinion.
45 hrs within radius of 100km from base is excessive in my opinion.
CAA told me they are working on bringing this down to 25hrs ? They are in discussions about this ?
CAA has however approved a range and endurance test routing that will be beyond the 100km radius from base.
No new snags :D
Think we found reason EFIS was rebooting after +-1.5hrs but will confirm after a few more flights.
As soon as the wheel pants and gearleg fairings are fitted we will tackle the left roll tendency snag.
Otherwise we are extremely pleased with the performance of the aircraft and are looking forward to flying off the 45Hrs.
frikie
HASSELL checks
Has liked: 10 times
Been liked: 15 times
Unread post by frikie » Fri Oct 11, 2013 5:55 am
Hi Dornier
It might be worth you while to chat with ACEMAN, he had the same 45 hours problem, and got it sorted in 5 min.
ilikeadornier
Engine Cranking
Unread post by ilikeadornier » Fri Oct 11, 2013 6:01 am
Thanks will chat to ACEMAN.
ilikeadornier
Engine Cranking
Unread post by ilikeadornier » Thu Oct 17, 2013 10:45 am
The CAA has agreed to let us apply for the initial authority to fly after 25hrs.
I wrote them an e-mail requesting this and included a list of the snags we have had.
Their only requirement was that the inspection for the initial authority to fly be done by
The AP who did the inspection for the proving flight authorization.
The aircraft now has 23.8 Hrs on it with no new snags.
The EFIS does not reboot any longer inflight,we switched off the data recording on a flight,and have left it off
On subsequent flights.Suspect that this was causing the problem.
We will fly the remaining 1.2 Hrs this weekend and then apply for the authority to fly.
frikie
HASSELL checks
Has liked: 10 times
Unread post by frikie » Thu Oct 17, 2013 10:59 am
Mooi!
ilikeadornier
Engine Cranking
Unread post by ilikeadornier » Tue Oct 29, 2013 5:07 pm
CAA issued the authority to fly yesterday no problems.
Aircraft can be seen at Parys this coming Saturday.
Jan
Closest Airfield: COVES
Unread post by Jan » Tue Oct 29, 2013 6:13 pm
Mooi man =D> =D>
Flying is about discipline!
AP325
ilikeadornier
Engine Cranking
Unread post by ilikeadornier » Tue Oct 29, 2013 8:30 pm
Dankie Jan !!!!! :D :D :D :D :D :D :D :D :D :D
ilikeadornier
Engine Cranking
Unread post by ilikeadornier » Tue Oct 29, 2013 8:31 pm
What can i say RV-GRIN :D :D :D :D :D
sweptwing
Has liked: 43 times
Unread post by sweptwing » Tue Oct 29, 2013 8:36 pm
Fantastic! En die Rating?
