Here we go again - RV10 build
ibeaton
Closest Airfield: Tedderfield
Re: Here we go again - RV10 build
Unread post by ibeaton » Mon Oct 01, 2018 7:52 pm
Got the controls and seats done:
A little bit of wiring:
Then we worked on the doors again, after a break from the fibreglass work we got back to it.
So doors joined, and locking mechanism installed. Next to get them to fit, then hinges and glass.
That is it for now.
Build on....
Ian
Vans RV7 ZU-FSG complete.
RV10 QB is under way
Empennage complete
Tail cone complete
Fuselage largely complete
Electrical and avionics complete
Finishing kitcomplete
Firewall forward
Wrapping up wings
Jan
Closest Airfield: COVES
Unread post by Jan » Mon Oct 01, 2018 8:34 pm
Take your time when trimming those doors to fit. Not easy.
Flying is about discipline!
AP325
Horace Blok
Closest Airfield: FAMO
Been liked: 39 times
Unread post by Horace Blok » Tue Oct 02, 2018 5:42 am
Looking good Ian & Theo. It’s such a sensible aircraft to own on so many levels. Look forward to reading more of your build adventures.
Hartog
ibeaton
Unread post by ibeaton » Tue Oct 30, 2018 12:15 am
So a lot of work later and we have prepped the inside of the cabin and applied the final colours.
Most annoying, the pictures are the right way up when viewed on the PC, but AVCOM seems to rotate them.
Any one with some suggestions?
So the panel is installed, wiring essentially complete, we are awaiting a number of circuit breakers and we will then be able to power it up.
So it is all moving along rather nicely.
Next is to paint the inside of the doors, the fit windows, lift it up for some wheels and spats, then fit an engine, propeller and spinner, sort out the cowls and finish the wings, send it off for paint, get the seats done, rig it all up, then go fly. Not too much to do.
To date we have logged 1173 hours in total. Sort of on track for our planned 1700 hour target.
Build on....
Empennage complete
Tail cone complete
Firewall forward
Wrapping up wings
Closest Airfield: FASY
Has liked: 199 times
Been liked: 97 times
Unread post by Mrb13676 » Wed Oct 31, 2018 8:38 am
Looks really good! Looking forward to seeing the end result.
Mike Blackburn
ZU-IBM - Sling4 Turbo s/n 009
RudiGreyling
Closest Airfield: The Coves
Has liked: 14 times
Been liked: 14 times
Unread post by RudiGreyling » Thu Nov 08, 2018 10:32 am
Well Done...you are getting there! I really enjoyed the avionics part, especially after all the fiberglass work!
Amateur Kit Builder
Closest Airfield: Venus
Has liked: 44 times
Been liked: 187 times
Unread post by Chalkie » Sun Dec 23, 2018 2:54 pm
Looking at your interior pics, some observations / advice...
The instrument panel and handhold holes are too flexible / weak and have a sharp trailing edge which can cause serious panel rash in an out landing. I take a length of 3003 soft ally fuel pipe and split it on one side. Easy to do, drill a 10mm hole through a block of wood and push the pipe through then split one surface with a grinder and cutting disc. No deburring, place this over the sharp trailing edge of the glare shield and drill a few 1mm holes and wirelock the pipe in place with .020 wire then split a 3/8 rubber hose with a knife and fit it over the tube and wirelock in place. Fill contours with firm foam and cover with leather.
The centre console / tunnel. Ensure you can remove a section ahead of fuel selector and behind rudder pedals to access the fuel pump and fuel flow tx. A hole on the side of the tunnel is also advised. That way you can get two hands in to do the job.
The windscreen. Do you plan to use Van's glue or Sikaflex? Sika 295UV is great but needs to have an exposed joint (no paint) to allow for flex.
Enjoy the build. The RV-10 is an awesome machine. :D
ibeaton
Unread post by ibeaton » Fri Dec 28, 2018 7:25 pm
Thanks Chalkie,
We will be putting some forehead protection on the leading edge of the panel shield, it has already claimed a few trophy dings in Theo's head, mine is much harder and does not seem to bleed as easily. I do not have any pictures of the damage to upload.
The plan for the windows is Sika, and we have kept the fiberglass raw in the joggle, so no paint in there.Also do not plan to cover the join with paint as it will certainly crack.
We made up a throttle for the incoming air using some PVC pipe and a servo to control the butterfly,, works nicely and saved some $200 for the one sold by Aerosport.
The build is progressing well, we textured the interior of the doors and then sprayed and finished up with a matt clear coat, we are very pleased with the results.
Empennage complete
Tail cone complete
Firewall forward
Wrapping up wings
RSH
Unread post by RSH » Tue Aug 27, 2019 1:13 pm
Good afternoon Gents how is your project coming along ? :D
ibeaton
Unread post by ibeaton » Tue Aug 27, 2019 6:19 pm
It is moving long.
Been a bit slack with updates here.
First front wheels on. Spats done.
So baffles done too, now busy building a plenum.
That is it for now.
Build on....
These users liked the author ibeaton for the post (total 2):
ACE MANHorace Blok
Empennage complete
Tail cone complete
Firewall forward
Wrapping up wings
Has liked: 44 times
Unread post by Chalkie » Tue Aug 27, 2019 6:51 pm
Awesome =D> =D> =D>
90% done, only 90% to go. Your comment, the doors sure fit nicely. Remember the lid does flex so do not make the fit too close, you will end up chipping the paint. I have some new CB's and CB switches, mostly 5Amp.
The RV-10 is an awesome machine. Hang in there...
ibeaton
Unread post by ibeaton » Tue Sep 17, 2019 5:55 pm
So after a visit to Dawie and Jan at the Coves, some effort largely from Theo went in to making a plenum.
This is the result:
This picture wont rotate. Grrr, anyone tell me how to do it and I will fix it. Tried saving it in different direction but it seems Avcom only likes landscape.
So now we have the connection from the air cleaner to the cowl to do and install our landing light. After that it is wrap up and then fuselage off to the hanger get the wings in for wingtips lights pitot and what not.
The end is in sight.
Build on.....
Empennage complete
Tail cone complete
Firewall forward
Wrapping up wings
Jan
Unread post by Jan » Tue Sep 17, 2019 7:11 pm
Well done on rolling your own plenum lid :D
AP325
ibeaton
Unread post by ibeaton » Tue Sep 17, 2019 9:01 pm
We had a little help from our friends, seriously the visit to you and Dawie showed us how to go about it. An hour spent with each of you probably saved us dozens and gave us the confidence to get on with it.
Thanks to both of you.
Ian
Empennage complete
Tail cone complete
Firewall forward
Wrapping up wings
Has liked: 497 times
Been liked: 144 times
Unread post by ACE MAN » Tue Sep 17, 2019 9:25 pm
Sorry to miss you on Saturday , next year we see you two in the 10!
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
