RV-12 by Bennie
bennie
Closest Airfield: FAWK
Re: RV-12 by Bennie
Unread post by bennie » Mon Jun 06, 2011 9:53 pm
Hi Bennie
You have the only RV12 build thread to follow in SA and there is only two RV12 in SA flying at the moment. We are waiting in anticipation for your next posting and progress.
No pressure hey?! I know there are other builds out there that can become good threads.....
May was a month of hardly any build production and this month to date, only deburring of the cone skins - that took a while with no visual reporting.
Hope to report more soon.
Bennie
bennie
Re: RV-12 by Bennie
Unread post by bennie » Sun Jul 03, 2011 3:18 pm
Hi RV’rs
Managed a couple of hours preparing the fuselage bulkhead as well as a lot of small parts required that will enable empennage attachment - all to make up a good prime session.
The photos should tell the story rather.....
Bennie
bennie
Re: RV-12 by Bennie
Unread post by bennie » Sun Jul 03, 2011 3:37 pm
A couple of more photos on the Fuselage Bulkhead showing the rivet detailing – quit involved!
Those AN470’s make you work with the squeezer – and there are plenty to squeeze!
Riveting next then!!
Bennie
bennie
Re: RV-12 by Bennie
Unread post by bennie » Sun Jul 03, 2011 3:39 pm
Eish! Die Brits! Will keep on trying!
Bennie
RudiGreyling
Closest Airfield: The Coves
Has liked: 17 times
Been liked: 21 times
Re: RV-12 by Bennie
Unread post by RudiGreyling » Tue Jul 05, 2011 8:41 am
Looking good. Make that piece nice straight and strong! The Stabilator hinges on it, and it brings the rear tailcone together, so it is important to get it as good as you can. Rudi
Amateur Kit Builder
bennie
Re: RV-12 by Bennie
Unread post by bennie » Mon Nov 21, 2011 7:08 pm
Hi all
Did not fade away completely. Managed to get a few things done but did not get to posting. Will try to get the posting up to date with current progress.
Below the fuse bulk head rivet exercise completed.
Bennie
bennie
Re: RV-12 by Bennie
Unread post by bennie » Mon Nov 21, 2011 7:17 pm
Then, just to keep all things balanced, a bit of gliding with Christiaan - our first flight togther. Look at all the rivits a "blik" glider nogal.
Then on to building with many holes of deburing as well lengths of edge deburring. Decided to do all the cone skins together - took a while
Bennie
griffio
Climbing Out
Closest Airfield: mosselbay
Re: RV-12 by Bennie
Unread post by griffio » Mon Nov 21, 2011 8:35 pm
bennie wrote:Then, just to keep all things balanced, a bit of gliding with Christiaan - our first flight togther. Look at all the rivits a "blik" glider nogal.
Bennie
hall Bennie
dit lyk my Cristiaan sit daar agter en se vir jou ;NOU WAT NOU :) :) . Dis goed om te sien jy hou die gliding by,daar is niks lekkerder as n ordentloke vlug,sonder die uitlandings of hoe =D> =D> .sal kom draai maak wanneer weer in jou wereld is ,ek sien jy vorder met earie
groete
marcel
bennie
Re: RV-12 by Bennie
Unread post by bennie » Mon Nov 21, 2011 8:54 pm
Dankie Marcel. Ja ons probeer die damme vermy.......... :lol:
Ja, sou graag wou vinniger gaan met die bou.....moet maar werk om die res van die vliegtuig te kry.
Groete
Bennie
bennie
Re: RV-12 by Bennie
Unread post by bennie » Mon Nov 21, 2011 9:21 pm
To get the prime "negative mask" cut lines in the palstic and check that all fits well, the skins were put together. The openings for skin J-stiffener in the fuse frames needed enlargement in places.
And then remove all the clecos again just to be put back for final rivet when removed finally again!!! Very glad the holes are pre drilled and mach drilled!
Bennie
ibeaton
Closest Airfield: Tedderfield
Re: RV-12 by Bennie
Unread post by ibeaton » Mon Nov 21, 2011 9:56 pm
Nice to see some updates again Benny.
Well done and keep it up, for us the end is almost in sight now.
Ian
Vans RV7 ZU-FSG complete.
RV10 QB is under way
Empennage complete
Tail cone complete
Fuselage largely complete
Electrical and avionics complete
Finishing kitcomplete
Firewall forward
Wrapping up wings
Johan RV
Closest Airfield: Kitty Hawk
Re: RV-12 by Bennie
Unread post by Johan RV » Tue Nov 22, 2011 3:27 am
Voorwaarts Bennie dit begin amper na n vliegtuig lyk :arrow:
bennie
Re: RV-12 by Bennie
Unread post by bennie » Tue Nov 22, 2011 6:54 am
Thank you Gents!
Still catching up with photos. Bottom skins at point of edgebreaking completed and primed. The edge breaking was a concern for me - if that is messed up it is very visable. So bought the best tool to do it and gave it my best effort - luckilly the first trials are on the bottom skins!!
Bennie
RudiGreyling
Has liked: 17 times
Re: RV-12 by Bennie
Unread post by RudiGreyling » Tue Nov 22, 2011 8:19 am
Baie mooi, binnekort gaan jy 'n rear fusalge in jou garage h^e!
Amateur Kit Builder
bennie
Re: RV-12 by Bennie
Unread post by bennie » Tue Nov 22, 2011 7:42 pm
Evening again.
Yes Rudi - not put together though until the wings are done - will need space for the wings in this small areas first
Some more photos after the priming and edge breaking, all was put together again and rivetted together. Side skins next.
Bennie
