Versatility
Sideslip
Closest Airfield: Springs
Versatility
Unread post by Sideslip » Thu May 09, 2013 10:29 pm
- “May I help you sir?”
- “Yes .. I’m looking for an really rugged yet affordable aircraft to head out into the bush. What do you recommend?”
- “Ahh sir, have you considered a BushCat?”
- “Hmmm .. the BushCat ... We actually I am looking for something that’s inexpensive to run and easy to maintain.”
- “Yes sir ........ the BushCat”
- “I am undecided about whether to go for a taildragger or a nosewheel aircraft at this stage.”
- “The BushCat comes in nose wheel or tail wheel config sir.”
- “I want to be able to fly with the doors off in summer but it must be equipped with a cabin heater for winter”
- “The BushCat sir ...... it is just as comfortable in all climates”
- “But the problem is I also would like an amphibian.”
- “Problem sir?”
Mike Gill
Raeflyer
Re: Versatility
Unread post by Raeflyer » Thu May 16, 2013 8:51 pm
=D> =D> =D>
✈✈✈ Stephen Haupt ✈✈✈
BushCat
Priming
Closest Airfield: FYWB
Re: Versatility
Unread post by BushCat » Sat Jul 13, 2013 7:25 pm
Would you please give us an after sales issue solving scenario too?
Byron Lutzke
Closest Airfield: FARA- Petit Airfield
Re: Versatility
Unread post by Byron Lutzke » Sun Jul 14, 2013 5:46 pm
What is wrong BushCat?
Sukkelaar
Avionics Master On
Re: Versatility
Unread post by Sukkelaar » Tue Jul 16, 2013 9:39 pm
Lots of weight shift trikes available for sale much cheaper
than what you can build them for.
See the microlighters forum
Kyk Noord
AWACS
Tripped over wheel chock
Re: Versatility
Unread post by AWACS » Tue Jul 23, 2013 8:28 pm
Uhh sir, does it have proper brakes?
Ooh ja well, we may have a problem on them here.....
Byron Lutzke
Re: Versatility
Unread post by Byron Lutzke » Wed Jul 24, 2013 9:16 pm
Hahaha what problems?
BushCat
Priming
Re: Versatility
Unread post by BushCat » Fri Jul 26, 2013 9:21 am
Problems ? No problems !
Is your BushCat in your hangar ?
AWACS
Re: Versatility
Unread post by AWACS » Fri Jul 26, 2013 6:32 pm
Brakes my friend, proper brakes for an otherwise great aircraft.
That is the issue here!
Alas.......no action from the factory for more than a 100 Cheetah pilots.
Byron Lutzke
Re: Versatility
Unread post by Byron Lutzke » Sat Jul 27, 2013 2:07 pm
I have had the privilege of receive the latest BushCat and have no problems obviously with the new breaking system. But AWACS why don't you approach Walter or Mike at Springs and ask about upgrading your brakes on the old model cheetahs to the hydrolic set up?
AWACS
Re: Versatility
Unread post by AWACS » Mon Jul 29, 2013 8:00 pm
Thank you BL.
Will do that -I hope they will support a Black Max brake upgrade on the Cheetah fleet out there?
Byron Lutzke
Re: Versatility
Unread post by Byron Lutzke » Mon Jul 29, 2013 9:56 pm
It is what they currently offering on the BushCat so they should for sure and replys will be slow while they busy in Oshkosh, but the factory is very helpful indeed.
AWACS
Re: Versatility
Unread post by AWACS » Tue Jul 30, 2013 8:52 pm
Sure BL.
But please take into consideration that the Bushcat is a new product that need sales.
The issue with the Cheetah fleet is ....customer support.
You better hope the is no follow-up on the Bushcat then maybe you will understand what I mean....not meaning to blast mike and the guys but its reality unfortunately.
We will approach them and report back on the Forums...
Byron Lutzke
Re: Versatility
Unread post by Byron Lutzke » Tue Jul 30, 2013 9:19 pm
I hope they help you out. I find them to be a really nice bunch of guys, please keep us up to date AWACS.
BushCat
Priming
Re: Versatility
Unread post by BushCat » Wed Jul 31, 2013 9:29 am
AWACS wrote:Sure BL.
Unfortunately I do understand what you mean. If you are interested in better brakes send me a PM
Return to “Cheetah”
