Engine mountings.
MidlifeCrisis
Engine mountings.
Unread post by MidlifeCrisis » Tue Aug 11, 2009 12:08 pm
I have found the rubber mountings that mount to the engine have a outer lip which has torn off, I contacted Rainbow and it seems to be ok to fly since there is no metal to metal contact,has anyone experienced the same thing.
Stephan van Tonder
Closest Airfield: Petit
Been liked: 11 times
Re: Engine mountings.
Unread post by Stephan van Tonder » Fri Aug 21, 2009 9:34 am
Which engine. We had not noticed anything. How many hours.
MidlifeCrisis
Unread post by MidlifeCrisis » Mon Aug 24, 2009 8:17 am
I have a 912s engine with 140 hours.
John Boucher
Closest Airfield: Mossel Bay - FAMO
Been liked: 31 times
Unread post by John Boucher » Tue Sep 01, 2009 11:01 am
I had it that those mounts were supposed to be changed at say 100-150hrs?
I have found that depending on what prop is used they do tend to "collapse" in different grades...
I have replaced mine recently, including the barrels and mounting washers. Really not an expensive exercise just a tedious one depending on the type of engine mounts you have. The newer models do have a different mount.
MISASA Chairman
Return to “Cheetah”
