TWENTIETH WHISPER TO FLY
The ultimate in personalized, recreational aviation ccovering both the Whisper motor glider and the Whisper Express.
whisper
Steep Turn Left
Unread post by whisper » Tue May 26, 2009 12:41 pm
Of the 52 whisper kits produced 20 aircraft are now completed and flying :D
A full build history of this particular aircraft is available at http://www.whisperaircraft.blogspot.com/
Steve
Closest Airfield: Wings Park
Has liked: 15 times
Been liked: 14 times
Re: TWENTIETH WHISPER TO FLY
Unread post by Steve » Tue May 26, 2009 3:56 pm
What's the latest on that 4 seater twin that a proof of concept model was built and flown?
http://www.whisperaircraft.com/forum/ph ... php?id=473
Would make a lot of sense for a twin Jabiru engined aircraft for training / pleasure flying....
Steve Onions
whisper
Steep Turn Left
Unread post by whisper » Tue May 26, 2009 4:05 pm
You're right it would make a lot of sense. Our quarter scale model flies really well. It also spins particularly well. Luckily it also stops spinning promptly with the correct inputs! Scale factor may be an issue here or perhaps it is just the aerofoil we chose for the model. Assuming we can tame that aspect (which I am sure we can) we will pursue that project at some point. In the interim the Whisper X is on the cards. Lycoming 160Hp 2 place side by side with much the same dimensions as an RV7 but built using the Whisper methods and most of our hardware, parts etc as well as a very similiar cockpit.
Arie de Wet
Closest Airfield: OMDB
Unread post by Arie de Wet » Thu May 28, 2009 10:33 am
Go for it Russel
I will be one of the first to buy a kit for your "plastic RV" =D> =D> =D>
Just make it a quick build please [-o< [-o<
bullet
Unread post by bullet » Thu Jun 04, 2009 5:39 am
Russell,
What`s the ETA of the "plastic RV" ? Sounds like something to look forward to ! Go for it ! =D>
whisper
Steep Turn Left
Unread post by whisper » Thu Jun 04, 2009 10:51 am
probably take a year...will start once have a bit of development capital hence:
viewtopic.php?f=2&t=48049&p=573132#p573132
Return to “Whisper Aircraft”
