WHISPER X
The ultimate in personalized, recreational aviation ccovering both the Whisper motor glider and the Whisper Express.
Kobus
Closest Airfield: Donkerhoek private strip
Re: WHISPER X
Unread post by Kobus » Sat Aug 25, 2012 5:28 pm
Baie geluk Russel. Dis werklik n prestasie.
Het jy al moontlik staak en eindnadering syfers.
Sal n 0-320 ook kan werk, wat is jou lee gewig
Kobus
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Mon Sep 03, 2012 2:29 pm
Hi Kobus
Thanks!
63MPH indicated stall speed (clean).
580kg
0-320 will work - takeoff just won't be quite as sprightly as with the 360.
I approach at 80MPH but will slowly work this down to about 75.
R
Luscombe47
Re: WHISPER X
Unread post by Luscombe47 » Sat Sep 08, 2012 8:42 pm
Hi Russell, any flying this weekend ? Interesting where the speed will go !
Goedgaan.
Johan
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Sat Sep 08, 2012 8:47 pm
I flew today but spent the time in the circuit experimenting with the mechanical flap system. Looks like I will rip it out and install an electric flap actuator. Didn"t go over 190MPH today.
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Mon Oct 15, 2012 9:42 am
2.5hrs this weekend - all good
Joined the Algoa Flying Club on part of their poker run which included landings at Uitenhage and AJ's.
Pics taken by Rego Burger using his cellphone (from Brett Routly's RV)
Etienne
Re: WHISPER X
Unread post by Etienne » Tue Oct 16, 2012 7:25 am
Was that taken as you blasted past them? :D
Gravity sucks.
Gravity never loses - the best you can hope for is a draw.
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Tue Oct 16, 2012 9:00 am
MarkB
Re: WHISPER X
Unread post by MarkB » Wed Oct 17, 2012 9:27 am
Hi Russell
When do think you will be able to release specifications and performance figures.
Mark
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Wed Oct 17, 2012 9:36 am
Hi Mark
Within a few weeks. I need to do a proper climb test and also get the coarser prop on to allow wide open throttle. The numbers so far are looking rather promising!
R
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Tue Oct 30, 2012 11:36 am
new shape rudder balance - solved the slight fishtailing that previously occurred in turbulence :D
MarkB
Re: WHISPER X
Unread post by MarkB » Wed Dec 05, 2012 11:10 am
Hi Russell
Anything further on specs, performance and any other relevant information.
Mark
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Wed Dec 05, 2012 11:30 am
Hi Mark
Still expanding envelope. 213MPH so far. Need to get to Vne of 230 still. Cruise looks to be over 200MPH at sea level!!. Have clearance from CAA to do two longer flights over the next few weeks during which I'll get more accurate data. (been restricted to 100km so far). Currently about half way through the proving flight hours and so far apart from the alternator problem there have been no snags. Have also expanded the G to around 3 and checked roll rates with aileron rolls. All in all looks to be a VERY sweet aerie!!
R
MarkB
Re: WHISPER X
Unread post by MarkB » Wed Dec 05, 2012 1:45 pm
Extremely fast machine and I would hazard a guess that it must have a very nice roll rate. Will hopefuly see it in the flesh shortly. What will she stall at with full flaps down?
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Wed Dec 05, 2012 3:40 pm
Just under 60mph but want to check calibration of ASI before I release an official figure
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Sun Dec 16, 2012 12:55 pm
finally found an RV to fly next to....Thanks Roy for our short formo sortie. The good news is that the X easily holds its own against an RV6 (with constant speed prop)!! In fact it seems quite a bit faster... Screenshot below at the end of our formo sortie....there was a light tailwind so the 180kts is more like 170kts or so.
Today was also the first flight with near full tanks. Climb test at 120kts (cruise climb) averaged around 1100'/min.
Return to “Whisper Aircraft”
