WHISPER X
The ultimate in personalized, recreational aviation ccovering both the Whisper motor glider and the Whisper Express.
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Fri Feb 22, 2013 9:10 am
Pic from John Miller photo shoot last week
MarkB
Re: WHISPER X
Unread post by MarkB » Mon Feb 25, 2013 10:15 am
Hi Russell
Do you have final spec's and performance data yet.
Mark
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Mon Feb 25, 2013 12:07 pm
See www.whisperaircraft.com/wcont
New website about to go live!
MarkB
Re: WHISPER X
Unread post by MarkB » Mon Feb 25, 2013 1:18 pm
Great
ADB
Power off Glide
Re: WHISPER X
Unread post by ADB » Sat Mar 02, 2013 7:30 pm
Thanks for the flip this morning, Russell! What a great aircraft. Fast and aerobatic - look out, RVs!
Andrew
Warbirdsfly
Closest Airfield: FAWB FAWK
Re: WHISPER X
Unread post by Warbirdsfly » Tue Apr 30, 2013 8:15 pm
Beautiful pic John
Warbirdsfly
Rules are made for people who aren't willing to make up their own - Chuck Yeager
In the end everything will be fine. If its not fine its not the end
KEO
Has liked: 13 times
Been liked: 17 times
Re: WHISPER X
Unread post by KEO » Wed May 01, 2013 4:23 pm
Hd a great flight to Paradise Beach this morning. Clocked 184 knots coming back :D Thanks Russell.
I must hurry and complete my rudder!! (.. and wing, and horizontal stab etc.. :( )
Brett Williams
Whisper X-350 ZU-TCC
Craigb
Closest Airfield: Elko
Re: WHISPER X
Unread post by Craigb » Sun Aug 04, 2013 4:18 pm
This seems like a fairly high performance plane? I assume it is not the best option to learn to fly in or am I wrong?
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Sun Aug 04, 2013 6:04 pm
It is a high performance aircraft and probably an unlikely ab-initio trainer however with patience and a willing instructor you can learn to fly in almost anything! IMHO it is better to learn to fly in an aircraft that needs to be flown rather than an aerial platform such as a C152 or similar. The latter does the job but when it comes time to step up it takes longer than it should to get your feet working etc. A good example is taildragger training... a person who starts from scratch generally goes solo in a taildragger in less time than it takes to convert a licensed nosewheel pilot to a TD... unlearning takes longer than learning!
Craigb
Re: WHISPER X
Unread post by Craigb » Fri Dec 06, 2013 5:53 pm
How many of these are flying now? Is it still only ZU-GAB?
Russell Phillips
Rotating
Closest Airfield: FAPE
Been liked: 18 times
Re: WHISPER X
Unread post by Russell Phillips » Fri Dec 06, 2013 6:13 pm
Yes. 6 others under construction. 2 quite close to finished.
Craigb
Re: WHISPER X
Unread post by Craigb » Fri Dec 06, 2013 7:29 pm
Are any of the guys keeping a builders log / diary on the net anywhere?
Craigb
Re: WHISPER X
Unread post by Craigb » Sun Dec 08, 2013 9:35 pm
whisper wrote:
MarkB wrote:Russell how long do you estimate the build time to be for someone who wants to build one,assuming you are a first time builder?
2000-3000hrs from a basic package. 2-3 years part time?? Beats watching TV :twisted:
Is this still the rough estimate for the build time for a novice?
whisper
Steep Turn Left
Re: WHISPER X
Unread post by whisper » Sun Dec 15, 2013 2:36 pm
Hi Craig
Bargain on at least 1000hrs if working from a basic kit. If its your first build 1500 is probably safer though. (2 years part time).
If working from a fast build package you can halve those numbers.
Have a browse here as well https://www.dropbox.com/sh/a5fqv7f6m71vmo7/hRiXvJEV_L
It is a lot of work but the end result is really something quite special :D
Russell
pieter001
Power off Glide
Closest Airfield: NZWN
Re: WHISPER X
Unread post by pieter001 » Thu Feb 13, 2014 2:07 pm
Hi Russell,
The planned Vne is 230mph.
With the new ground adjustable prop (and carb), what speed did you achieve?
I'll start my build REAL soon, kit is almost 100% complete ito parts to assemble :D, excluding the engine :( Will need to save for a long while for it, but that is build time!
Pieter
ZS-CBW Mooney M20E - Plane Jane -> Sadly she is no more
Building a Whisper X
Return to “Whisper Aircraft”
