D-Motor powered Explorer ZU-FTD
stefan
Closest Airfield: FARA
Been liked: 59 times
Unread post by stefan » Mon Mar 12, 2012 8:17 pm
D-Motor powered Explorer under construction. We have aquired the African agency for the D-Motor. The engine will be ideal for use in trikes and LSA planes. It is fuel injected and the fuel burn is only 14l/hr at full power. The engine averages 10l/hr. There is a 120hp version in the pipe line which will be available by the end of 2012. See also our tread at http://www.microlighters.co.za/viewtopi ... 7&start=30
stefan
Re: D-Motor powered Explorer
Unread post by stefan » Mon Mar 12, 2012 8:23 pm
toomanyswitches
Steep Turn Right
Closest Airfield: FAHT
Unread post by toomanyswitches » Sat Apr 21, 2012 11:46 am
This is a very interesting motor. I was at Kitplanes today flew in from Hoedspruit and took a look at the engine. It would be interesting to see how they perfom in the market.
Anyway, nice meeting you Stefan :D
stefan
Unread post by stefan » Sat May 19, 2012 10:05 am
Getting there
stefan
Unread post by stefan » Fri Jun 29, 2012 8:44 pm
Engine running perfect. The installation was very simple and straight forward. We weighed the plane and even with all the extra's we installed she came in at 317,5kg. That gives us a useful load of 282,5kg and an endurance of just under 11 hours at cruise speed.. =D> =D> =D> We have a winner.
Of to CAA on monday for the paperwork. This baby is smelling the air
stefan
Re: D-Motor powered Explorer ZU-FTD
Unread post by stefan » Fri Jul 13, 2012 9:20 pm
First flight should happen tomorrow if the weather holds :D
Bom
Mags Dead Cut
Unread post by Bom » Tue Dec 18, 2012 5:35 am
And?
FLY SMART,FLY SAFE - TAKE EVERY MOMENT YOU CAN TO ENJOY THE WONDERFUL WORLD OF FLYING.
stefan
Unread post by stefan » Tue Dec 18, 2012 3:11 pm
Have done about 8-10 hours flying in total. The motor is sweet but the cooling is a struggle. I am on the 4th radiator and it is only now at a stage where I can stay airborn for longer than a circuit. The PFA has expired so I will have to renew that before I can do more testing.
Jean Crous
Closest Airfield: FASX
Has liked: 341 times
Been liked: 151 times
Unread post by Jean Crous » Tue Aug 06, 2013 9:21 pm
:D En wat nou van hierdie enetjie ??????
Jean
Cubby Aircraft Factory
Cell : 072 6716 240
SACAA Approved Person 402
stefan
Unread post by stefan » Wed Aug 07, 2013 7:18 pm
I removed the engine to send back to Belgium for a upgrade to the new 95hp version but I have not gotten around to the shipping yet. I installed a Rotax in the airframe and sold it on so the D-motor will probably go into my trike in the 80hp form. I am waiting for their 6 cylinder to complete testing.
Jayson v Schalkwyk
Closest Airfield: Himeville
Been liked: 52 times
Unread post by Jayson v Schalkwyk » Thu Aug 08, 2013 8:52 am
Stefan,
Could this engine be fitted to the original Bushbaby? Would it maybe be to heavy?
How do they perform with a 582 and p-prop?
This tailwheel training has gotten me hooked....
Jayson
Jayson van Schalkwyk
stefan
Unread post by stefan » Thu Aug 08, 2013 9:06 am
Hi Jayson,
Yes they will fit the Bushbaby but I still need to get hold of the newer version engines to sort the cooling issues. This engine that I have produces too much heat for the closed cowl setup. They work perfect in trikes and aircraft like the X air where they are in the open. This engines weighs only 3 or 4 kg more than a 582 fully installed. The Bushbaby flies fine with a 582. Just keep it light and forget all the gadgets.
We warned you that tailwheel flying is addictive......... :roll:
Jayson v Schalkwyk
Unread post by Jayson v Schalkwyk » Thu Aug 08, 2013 10:11 am
what do you think of this
viewtopic.php?f=2&t=119355
stefan
Unread post by stefan » Thu Aug 08, 2013 10:13 am
Go for it.
Jayson v Schalkwyk
Unread post by Jayson v Schalkwyk » Thu Aug 08, 2013 10:15 am
How much is still left to complete before she would be able to fly do you think?
It tough to judge just from the photos
Return to “Bushbaby”
