EOS 550D not recognised by PC
ColdFingers
Closest Airfield: FADU Walkersons
Unread post by ColdFingers » Thu Jan 10, 2019 10:50 am
When I connect my trusty Canon EOS 550D to my PC with a USB cable I get a "USB device not recognised" message on my PC.
I have Googled and searched the Net far and wide without success.
The only way I can get pictures onto my PC now is with an SD card reader. It works, but a bit of a pain.
Numerous sources recommend reloading/upgrading the firmware on the camera but this is not possible as I cannot connect the camera to my PC!
The only clue I have is that, if I remember correctly, this problem started after upgrading my PC to Windows 10. But I cannot be 100% sure about this.
Any suggestions or help would be appreciated.
Andy Mills
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
Wonko the Sane
Closest Airfield: Wonderboom
Re: EOS 550D not recognised by PC
Unread post by Wonko the Sane » Thu Jan 10, 2019 11:08 am
Hi Andy
I usually remove my SD card to download as I have renamed the cards for specific purposes. I will check tonight if I have similar issues using the usb cable on my 550. Will keep you posted.
You can update Canon software over the cable or by copying the downloaded, unzipped file to a blank SD card and go to the system menu and choose the "use SD card" in the menu for firmware updates.
W
Andre Dethioux (temporarily in Angola...)
RPL (MR)
Unread post by cage » Thu Jan 10, 2019 11:14 am
worth checking if you need to load any canon software on your PC though these devices tend to appear as generic removable drives. Else firmware as suggested.
Unread post by jvdl » Thu Jan 10, 2019 11:55 am
Have you tried it on a different PC?
Also see: https://photo.stackexchange.com/questio ... n-eos-550d
Open Aircraft Register Project: https://aircraftregister.co.za/ <-- Intermittent uptime due to load shedding.
Unread post by Ray W » Thu Jan 10, 2019 12:01 pm
Reload your Canon software. That should help
ddevos
Closest Airfield: FAVV
Unread post by ddevos » Thu Jan 10, 2019 6:15 pm
Hi ColdFingers, have you tested the USB cable itself? Remember, these things do sometimes go faulty, no matter how well you look after them. Also try it with another cable, any standard mini-USB cable will work. I don't see the software as the cause of this problem.
Dirk de Vos
snoopy
Unread post by snoopy » Fri Jan 11, 2019 2:28 pm
Eish Windows 10 again...
Does it recognize any other device using the same USB cable? If not...
Have you tried this? Roll back the Generic USB Hub Driver for the ports on your motherboard. If the roll back works, it was a USB driver update for Windows 10 that caused it.
Microsoft loves using their own generic drivers, which are not specific to the brand of motherboard per se, and it can screw things up...it does the same with graphics cards.
They should nuke Win10. :twisted: :lol:
Vivere come se mai dovessimo morire
Wonko the Sane
Unread post by Wonko the Sane » Fri Jan 11, 2019 3:16 pm
Hi Andy
I connected just fine to Win10... Sorry I cant be of more help...
W
RPL (MR)
vanjast
Closest Airfield: 200
Unread post by vanjast » Sat Jan 12, 2019 2:31 am
Is there an option on your camera to set it up as a 'memory device' on USB.
Windows will then see the camera as a memory stick (no software installation required) and you can access the DCIM folders to upload the photos.
I do this with all phones and cameras.. works ok.
The supplied software that comes with the cameras are a pain where the sun don't shine.
ColdFingers
Unread post by ColdFingers » Sun Jan 13, 2019 1:25 pm
Thanks all for the suggestions and help. I've tried everything suggested but the problem persists. Looks like it is a hardware problem on the camera.
This is what I have done:
Upgraded the firmware to version 1.1.0. DId it via the SD card. Download files and instructions here. https://www.canon.co.uk/support/consume ... 14-1505802
Tried different USB cables.
Tried different PCs (still need to try a non-Windows10 PC)
Tried rolling back USB drivers.
Updated USB drivers
Reinstalled Canon software on my PC.
Next time I am in Pretoria/Jhb I will take it into a Canon shop for them to have a look.
Andy Mills
Return to “123.45”
