Solar power batteries
- Too Tousand
- Closest Airfield: GRJ
- Has liked: 324 times
- Been liked: 65 times
What is the best way to connect four batteries in parallel in a a solar power system?
I'm not old, I'm 18 with 46 years of experience
- Has liked: 5 times
- Been liked: 7 times
Re: Solar power batteries
I think you'll need to be a bit more specific on what info you're after...or maybe I'm being doff by not realizing the complexity of connecting batteries in parallel?
- Frequent AvComer
- Closest Airfield: Wonderboom
- Has liked: 3 times
- Been liked: 42 times
If it is a 12V system, then obviously you would need to connect the 4 batteries in parallel.
But because you have 4 batteries, it just raises the suspicion that maybe you have a 48V system, in which case you have to connect them in series.
When you connect them in parallel, connect the two wires from the solar system to the Positive on the first battery and the negative on the last battery in the pack.
You get special cables for the parallel connection because you have a terminal (the clamp for the battery terminal) with TWO wires coming out of it.
C
- Too Tousand
Yes it is a 12v system and I was wondering how to connect the controller as well as the inverter. Would you then connect the inverter on the opposite terminals to the controller if the controller is connected as you suggest above or to the same posts as the controller? At the moment I have two batteries which are inadequate, so will buy a further two.C Africa wrote: ↑Sat Feb 23, 2019 9:05 amIf it is a 12V system, then obviously you would need to connect the 4 batteries in parallel.
C
I've read that it is not simply a case of connecting 4 batteries in a simple parallel fashion as the battery nearest the inverter gives the most power while the last battery gives the least leading to premature failure during the recharge cycle.
- Too Tousand
It's apparently incorrect to just line them up and connect jumpers from one to the next, all paths to and from the battery bank must be as equal as possible leading to a complex way of connecting them up.
- Six Tousand
- Has liked: 417 times
- Been liked: 315 times
The right way to parallel batteries.
Connect charger & load to the same points as well. The idea is to have the same resistance = cable length on the positive & negative legs.
- Six Tousand
This is clearer. Ignore the 6 Volt label
- Too Tousand
Another question if I may? Can one mix batteries of differing brands but all the same A/hour rating? I have two Royal Delkor 1150K batteries of 105a/h rating and now the supplier cannot get any more. He has the Energizer ones of the same rating. I have a sneaking suspicion that they are both made by the same manufacturer.
- Six Tousand
Same manufacturer. Badge engineering
Look carefully, you may see Johnson Controls on both labels.
It only really makes a difference at high currents ie. greater than 25 amps on a 100 Amp Hour battery
- Too Tousand
Thanks PaulUgly Duckling wrote: ↑Sat Feb 23, 2019 12:39 pmSame manufacturer. Badge engineering![]()
- Too Tousand
How would you describe these batteries Paul, "sealed" or "flooded" and what is the difference between these types?Ugly Duckling wrote: ↑Sat Feb 23, 2019 12:39 pmSame manufacturer. Badge engineering![]()
- Six Tousand
They are sealed AGM, Abdorbed Glass Mat, but they fo have a vent tube which MUST NOT BE BLOCKED. If the battery is abused it may vent electrolyte from the vent.MadMacs wrote: ↑Sun Feb 24, 2019 1:41 pmHow would you describe these batteries Paul, "sealed" or "flooded" and what is the difference between these types?Ugly Duckling wrote: ↑Sat Feb 23, 2019 12:39 pmSame manufacturer. Badge engineering![]()
Flooded is any battery where electrolyte can be checked & added via easily removable vent caps. If you need a sharp object to pry the cap open it is Sealed.
- Too Tousand
Okay cool, thanks once again.
- Fife Thousand feet
- Has liked: 29 times
- Been liked: 158 times
Parallel batteries are actually a good example of Marxism. Each contributes according to its abilities. So even a small/old battery will contribute something to the total. Unless of course it is so badly stuffed that it is actively sabotaging the others.
Series on the other hand is completely different. There the pack is limited to the capacity of the weakest battery.
