White fly plague
Jack Welles
Has liked: 24 times
Been liked: 191 times
White fly plague
Unread post by Jack Welles » Sat Mar 30, 2019 1:28 pm
Especially on the tomato plants :evil:
Any farmers/gardeners out there with good ideas for the clearing up of our little veg garden of these pesky critters?
Eddie Haynes-Smart
Has liked: 214 times
Been liked: 80 times
Re: White fly plague
Unread post by Fransw » Sat Mar 30, 2019 1:35 pm
No political threads are allowed! [-X
Jack Welles
Has liked: 24 times
Unread post by Jack Welles » Sat Mar 30, 2019 1:58 pm
:lol:
Eddie Haynes-Smart
HJK 414
Closest Airfield: abcd
Has liked: 68 times
Been liked: 361 times
Unread post by HJK 414 » Sat Mar 30, 2019 2:36 pm
Eddie,
Your unwanted (but certainly thankful) visitors are : Aleyrodidae.
They love tomatoes and live under the leaves of the plant and bore into the "channels" that feed the plant and cause the plant to wither and ultimately die. Many are by now resistant to normal garden pesticides and will survive common aerosol deterrents.
The best solution as far as I know is citronellal - they do not like that.
You could try planting some Melissa Officinalis (the Citronellal plant) in between the Tomato plants.
The odour is enough to get the pesky buggers to contemplate emigration.
You can also dilute some citronella oil and spray the leaves with it (especially underside) - the oil will stick to the leaves
JK
Has liked: 85 times
Been liked: 82 times
Unread post by V5 - LEO » Sat Mar 30, 2019 2:50 pm
...or vinnegar and citronella oil solution for spraying, sorry do not have the ratio's.
Christopher
Has liked: 41 times
Been liked: 18 times
Unread post by Christopher » Mon Apr 01, 2019 11:58 pm
...or simply spray with dilute Jeyes fluid! Always worked for me in Durbs where there were plenty of nasty creatures after our veggies!
Shallowpig
HASSELL checks
Closest Airfield: FAAP
Has liked: 19 times
Unread post by Shallowpig » Tue Apr 02, 2019 11:21 am
I have used https://livingseeds.co.za/aphid-and-whi ... =white+fly, in my aquaponic system.
I couldn't risk poisoning my fish....
It is essentially a yellow card (to attract) with a glue that stays sticky but doesn't dry.
The flies gets stuck in the glue - and nothing else gets sprayed/polluted with pesticides and bad stuff.
Jaco
Jaco Barnard
Jack Welles
Has liked: 24 times
Unread post by Jack Welles » Tue Apr 02, 2019 11:28 am
The flies gets stuck in the glue - and nothing else gets sprayed/polluted with pesticides and bad stuff. Jaco
Interesting suggestion! Thanks! I'd agree that stuff like Jeyes Fluid should bump them off but then would worry about eating the lettuce etc afterwards. Not sure to what extent washing the veg would get the stuff off. Also checking the citronella story.
Thanks, guys. Interesting suggestions. Our soapy water spray hasn't been doing to trick.
:shock: Tough white flies in Muzies. Must be the ozone :lol:
Eddie Haynes-Smart
Marius Schrenk
Has liked: 128 times
Been liked: 66 times
Unread post by Marius Schrenk » Tue Apr 02, 2019 6:36 pm
Gewone Engelse sout in water sal die ding doen....spuit gereeld.....behoort ook iets te doen vir "constipation" as jy dit oordoen. :wink:
Return to “123.45”
