Any VW Beetle fundis on the forum?
Has liked: 51 times
Been liked: 43 times
Unread post by V5 - LEO » Fri Apr 26, 2019 12:24 pm
...hi gents, busy restoring a '72 beetle for a mate, wiring was horrendous - in specific I am looking at help from the little "box" mounted at firewall between motor and cabin, some thin red wire that seems to have lost the "where do I belong" position after been cut?
Ian.C
Priming
Re: Any VW Beetle fundis on the forum?
Unread post by Ian.C » Fri Apr 26, 2019 1:17 pm
Hi V5-LEO
Can you post a pic of the box
Has liked: 256 times
Been liked: 189 times
Unread post by Ugly Duckling » Fri Apr 26, 2019 1:32 pm
Possibly the voltage regulator wire to the generator field.
Dish
Closest Airfield: Panorama
Been liked: 11 times
Unread post by Dish » Fri Apr 26, 2019 3:03 pm
or the ceramic defibrillators. largely depends on whether its inverted or not...
Romeo E.T.
Has liked: 20 times
Been liked: 100 times
Unread post by Romeo E.T. » Fri Apr 26, 2019 3:15 pm
Has liked: 51 times
Unread post by V5 - LEO » Fri Apr 26, 2019 3:44 pm
Hi V5-LEO
...will do tonight if that is OK!
These users liked the author V5 - LEO for the post:
Ian.C
Has liked: 51 times
Unread post by V5 - LEO » Fri Apr 26, 2019 3:49 pm
...txs RET, that is the name for it Ian, the central plug. The red wire along with wires to the alternator (aftermarket) comes from the central plug, the red wire baffles me.
Unread post by Ugly Duckling » Fri Apr 26, 2019 4:54 pm
Engine has the following wires:
Oil pressure switch
Idle valve on the carb
Electric choke on the carb
Genny Alternator excitation
Genny Alternator charging
Coil power
Coil to points on distributor
Has liked: 51 times
Unread post by V5 - LEO » Fri Apr 26, 2019 5:05 pm
Oil pressure switch
Coil power
...txs UD , think it is for the electric choke then, all other wires have a nest.
Then there is up front (fuse box) also two wires I need confirmation from, but will post pics a bit later. Obrigado
Deanw
Been liked: 91 times
Unread post by Deanw » Fri Apr 26, 2019 5:15 pm
You can always ask this guy for help: viewtopic.php?f=8&t=218360
http://www.SAairforce.co.za
Has liked: 51 times
Unread post by V5 - LEO » Fri Apr 26, 2019 7:43 pm
.... :D :D we yeah that looks like me - would like to prevent it this time round.
Has liked: 51 times
Unread post by V5 - LEO » Fri Apr 26, 2019 8:12 pm
...ok the pics, the group of three wires comming out of the central plug - electric choke maybe?
...the brown wire with ehite banded stripes and multiple terminals - must be a ground of sorts?
....white wire, 3rd from left on fusebox - heaven knows and it is cut off at about 25 cm?
Ian.C
Priming
Unread post by Ian.C » Sat Apr 27, 2019 8:52 am
Not sure about the central plug but you could be right about the electric choke.
the brown wires will be earths yes.
the white wire on the fuse box doesn't look standard, maybe its was for a aftermarket steering wheel hooter.
Ian.C
Priming
Unread post by Ian.C » Sat Apr 27, 2019 9:14 am
found some info on the central plug, seems it was used as a diagnostic port for the VW dealer.
These users liked the author Ian.C for the post:
Oldlae
Has liked: 51 times
Unread post by V5 - LEO » Sat Apr 27, 2019 9:39 am
...txs gents, will comment with my success rate :D :D
Return to “123.45”
