Little car start boosters
Has liked: 298 times
Been liked: 224 times
Re: Little car start boosters
Unread post by Ugly Duckling » Mon Aug 19, 2019 2:47 pm
GL wrote:
Mon Aug 19, 2019 1:26 pm
UD - are you sure those little units haves a lead acid battery? - I rather imagined it was new Lithium Ion or whatever?
ie a new technology - and more ok for deep cycle heavy discharge.
I referred to the unit in Jack's last picture. That is LA, the others are Lithium.
HJK 414
Closest Airfield: abcd
Has liked: 53 times
Been liked: 282 times
Unread post by HJK 414 » Mon Aug 19, 2019 3:03 pm
Paul,
I recently replaced the battery in the wife's car.
It is a Gel "pack" battery - what's the diffs ?
JK
Unread post by Ugly Duckling » Mon Aug 19, 2019 4:41 pm
Paul,
JK
Lead acid batteries come in 3 flavors regarding the electrolyte system. Wet, Gel & AGM.
The Gill G35 in your C185 was a "wet" battery. If you turned it over without the caps the acid would run out.
"Gel" is where the acid is contained in a silica dust forming a putty. Some may be operated on their sides.
Then there are AGM "Absorbed Glass Mat" where the acid is contained in a fiberglass mat. The mat is as wet as an airline hand wipe.
HJK 414
Has liked: 53 times
Unread post by HJK 414 » Tue Aug 20, 2019 10:16 am
Cheers.
I can not remember what the C185 had …..
Do not have a conscious memory of ever any issues with starting up …….
The "advise" was to buy the Gel battery due to very low temps in winter (apparently Gel Batteries are less prone to "damage")
(Wife's car stays in Germany when we are in Spain - and stands idle in unheated Garage for months during frost periods).
No idea - price diffs was negligible ….
JK
Closest Airfield: FAPX
Has liked: 34 times
Been liked: 128 times
Unread post by Chalkie » Tue Aug 20, 2019 1:15 pm
I have one of those small modern battery jump starters (Li-something) and find it to be awesome at starting vehicles up to 3L Diesel. Paul can explain, I can't. If you hook it up to a dead battery and turn the key, not much happens so you give up. If you turn the key and hold it in 'start,' it takes a second or two to make the battery wake up and crank out the amps. Then it works like a charm and does not deplete much.
If you use it as a cellphone charger, it seems to lose an inordinate amount of charge.
Rule #2 Hurry up Slowly.
Learjet
Helicopter getting close
Closest Airfield: Morningstar
Unread post by Learjet » Tue Aug 20, 2019 9:13 pm
I have ones of these... absolutely brilliant. Get multiple jump starts out of a single charge and had no issue cranking my 4.7l V8 or my wife's diesel Kombi. Also handy to charge laptops / cellphones etc when traveling.
Dave Lehr
Magni M22 Voyager ZU-EPZ
Has liked: 35 times
Been liked: 93 times
Unread post by GL » Wed Aug 21, 2019 6:34 am
Thanks Dave - Thats the info i was looking for - where did you get it?
The essentials to happiness:
• someone to love,
• something to do,
• something to hope for
Guy Leitch
Faraway
Unread post by Faraway » Wed Aug 21, 2019 9:16 am
Hi Dave, what brand is the one you posted?
Learjet
Unread post by Learjet » Wed Aug 21, 2019 9:20 am
Guy,
Try Mark Becker at Morningstar as he imported some a few years ago and I got one from him. Adendorff Machinery Mart in Montague Gardens also stocks them for R895 https://www.adendorff.co.za/product/mac ... p-starter/
Regards,
Dave
Dave Lehr
Return to “123.45”
