Vehicle classification ?
skytrooper
Has liked: 13 times
Been liked: 23 times
Unread post by skytrooper » Wed Oct 09, 2019 9:26 am
Can anyone tell me how can i legally use a vehicle which will be more in a hover category than an aircraft, can i license it as a transport vehicle not an air vehicle.
I can't wait for the CAA to take 5 years to create a category for what essentially will be a just above hovercraft category that will (hover) just a bit higher than a hovercraft and over dams only. It won't interfere with any air traffic whatsoever.
1.It will not go higher than 50ft
2.it will only hover in a 100 meter radius over dams only. Maybe even just 1 dam.
Ubluwulululululu....!
Has liked: 39 times
Been liked: 337 times
Re: Vehicle classification ?
Unread post by heisan » Wed Oct 09, 2019 9:42 am
If it only operates in ground effect, then it is not an aircraft, and CAA has no say at all. If it operates out of ground effect, then it is an aircraft, and you have to go through CAA.
Has liked: 14 times
Been liked: 353 times
Unread post by cage » Wed Oct 09, 2019 9:44 am
50ft is a long way out of ground effect.
Has liked: 251 times
Been liked: 275 times
Unread post by V5 - LEO » Wed Oct 09, 2019 10:13 am
....best is to keep it as a hovercraft and when caught, excuse will be that there was a strong updraft - that kind of vehicle will bowl the caa over :shock: :shock:
...good luck! and let the cat out of the bag, show us some pics of this please?
Has liked: 14 times
Unread post by cage » Wed Oct 09, 2019 11:16 am
Until someone gets hurt or reports you, at which point you end up broke or in die tronk.
Unread post by V5 - LEO » Wed Oct 09, 2019 11:28 am
....yeah propably both, it is just utter frustrating what inventors / builders / tinkerers must go through to get new stuff (propably good stuff) in the loop for GA / aviation :idea: :?
skytrooper
Has liked: 13 times
Unread post by skytrooper » Wed Oct 09, 2019 1:04 pm
If i can find a way to do it i will post it, first need to see how i could possibly do it without CAA classification. i'm not going to bother any aircraft at all and it will only go over water.
Triaan
Has liked: 55 times
Been liked: 64 times
Unread post by Triaan » Wed Oct 09, 2019 1:12 pm
Well they are having a blast out of ground effect:
Has liked: 14 times
Unread post by cage » Wed Oct 09, 2019 1:22 pm
Not really, that is still "in ground effect", it's the water jet pushing off the water that lifts them, they are also properly tethered to a ground device that's doing the pumping.
Not the same thing by a long shot, That's like saying a scissor-lift needs an aircraft license.
Has liked: 39 times
Unread post by heisan » Wed Oct 09, 2019 1:45 pm
“aircraft” means any machine that can derive support in the atmosphere from the reactions of the air, other than the reactions of the air against the surface of the earth;
So this excludes, for example:
1) ground effect vehicles
2) rockets/non-air reaction vehicles (like those water jets)
3) ballistic vehicles.
If in any way you can prove that it does not meet this definition, then the CAA has no say over it.
If it does meet the definition, then your only real option would be an exemption application under CAR 11.04 (which may actually be easier than you think, if you engage civilly with the office of the director).
JCA
Closest Airfield: Krugersdorp
Been liked: 60 times
Unread post by JCA » Wed Oct 09, 2019 1:45 pm
Then its amazing how all the big jets fly with the jet blast pushing against all the airport buildings. Really Cage?? Talk to a fireman sometime or try a big fire hose.
Closest Airfield: Ermelo
Has liked: 99 times
Been liked: 607 times
Unread post by Whirly » Wed Oct 09, 2019 1:54 pm
#-o :lol: :lol: :lol: :lol:
Has liked: 14 times
Unread post by cage » Wed Oct 09, 2019 2:26 pm
So there is no interaction with the surface that assists with the lifting forces?
Unread post by V5 - LEO » Wed Oct 09, 2019 2:56 pm
[quote=cage post_id=2073261 time=1570623963
[/quote]
....think the concept is very much the same as a jet engine, differance being water, other than air being forced through the nozzles.
Has liked: 14 times
Unread post by cage » Wed Oct 09, 2019 3:36 pm
There is a reason that things that hover require more power to get a bit further away from the surface.
It's almost like the ground has some sort of effect..
Return to “123.45”
