Licensing Question
Questions for RAASA
jetstream16
Engine Cranking
Licensing Question
Unread post by jetstream16 » Wed May 12, 2010 9:58 pm
I have just purchased a Pietenpol Air Camper which is a 390kg (when empty) non-type certified, tail dragger aircraft.I do not have a license but obviously would like to get one. It is my understanding that the CAA has done away with the Microlight Pilots License and replaced it with the Sport Pilot License.
My questions are as follows:
1. If there are no instructors certified on this type of aircraft, how would I go about getting training on the aircraft?
2. With regard to Sport/Microlight training, is it still necessary for an instructor to train a student under a schools ATO license or are there provisions for freelance instructers?
3.Under the provisions of a Sport/Microlight license, does the CAA differentiate between a tricycle and tail-dragger NTCA's?
4. Where can I find more information about the Sport/Microlight license?
Thanks for any help!
Jet
WILDTHING
Re: Licensing Question
Unread post by WILDTHING » Thu May 13, 2010 8:46 am
Hi Jet, but with your new Pietenpol perhaps this should be Prop for now:lol:
The Microlight licence has been replaced withthe NPL National Pilots Licence with a LSA endorsement.
THe Pietenpol has a max take off of over 450kg and less than 600kg so this will fall into the LSA category, just make sure that your planes POH specs are within this range, you want to find it over 600kg MTOW or you would need a PPL.
You have two options
(a) A LSA Instructor at an ATO near you can get rated on type, you would need to get an ATF for owner training and have the plane listed on the ATO register.
(b) Train at an ATO on one of their planes and get type rated on yor Pietenpol later.
All instrcution has to be done under an approved Part141 ATO, The instrcutor and plane needs to be on the ATO register and all flights need to listed on the Autho sheets.
There is no differance in terms of the licence between tricycle and tail draggers, but your licence will be endorsed with a Tail dragger rating.
From RAASA or in Part 62 of the CARS & CATS
Hope this helps
Pierre
RAASA
Tel: 011 827 9330
Fax: 011 827 9329
www.raasa.co.za
Walid
Unread post by Walid » Sun Jun 20, 2010 3:33 pm
In Excel format. I could not read the PDF file.
DKN
Unread post by DKN » Thu Aug 26, 2010 8:36 pm
Walid Hi
What happened to the TMG Part
D
WILDTHING
Unread post by WILDTHING » Mon Aug 30, 2010 10:34 am
TMG Subpart 17 awaiting promulgation.
Return to “RAASA”
