Tu-22 down in Murmansk, 2 fatalities
- Frequent AvComer
https://www.google.com/url?sa=i&source= ... 0132986948
Just seen this. Apparently suffered a hard landing while landing in a blizzard. RIP...
Keith Windsor WcRostie Quixley (in case you were wondering)
- Too Tousand
- Closest Airfield: GRJ
Re: Tu-22 down in Murmansk, 2 fatalities
Don't worry about old age, it doesn't last long.
- Post Take off checks
- Closest Airfield: FAKT
Photo of the cabin and what looks like a fax of the report summary:
https://bmpd.livejournal.com/3506678.ht ... 06678.html
- Frequent AvComer
My guess is that with all that whiteness the pilot didn’t even see the ground in order to flare. Still, the ROD doesn’t look that high that the front section should just break off
Hop
Hop
- Tree Tousand
- Closest Airfield: LIMB
Incredible that anyone survived that! Apparently just the commander survived with serious injuries. Very sad. 3rd TU22 accident in as many years.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return"
- Too Tousand
- Closest Airfield: FACT
In that video it looks as simple as that, when the main wheels touched down the front half of the aerie simply fell off!Hop Harrigan wrote: ↑Sun Jan 27, 2019 9:28 amMy guess is that with all that whiteness the pilot didn’t even see the ground in order to flare. Still, the ROD doesn’t look that high that the front section should just break off Hop
Eddie Haynes-Smart
Eddie Haynes-Smart
- Too Tousand
Just before impact the engines spool up, I wonder if he decided to do a go-around?
- 10000 and still climbing
- Closest Airfield: FAGG
Very strange, the impact didn't look that hard.
"So Others May Live", "PPL Manual", "Flight Tests", and "Flying in Africa" Volumes I & II. Look inside these books, and buy them at: www.jimdavis.co.za.
- Closest Airfield: Cab
I thought it looked hard, but difficult to put descent rate into context.
This video shows one of the prototype DC-9 aircraft that got things wrong during a certification flight test:
— Charles A. Lindbergh
- Tripped over wheel chock
- Closest Airfield: FAPG
That was a huge rate of descent which even the thrust increase did not seem to arrest. Wonder if he also got a little slow? Not easy to pop out of cloud in blizzard conditions like that and accurately assess sink rates.
- Last nights Garlic 'repeats' itself.
- Closest Airfield: FAWB
Not sure if it's mentioned in the report, but on another forum they say the airframe is limited to 4G and the impact was at 7.4GsJack Welles wrote: ↑Sun Jan 27, 2019 11:28 amIn that video it looks as simple as that, when the main wheels touched down the front half of the aerie simply fell off!Hop Harrigan wrote: ↑Sun Jan 27, 2019 9:28 amMy guess is that with all that whiteness the pilot didn’t even see the ground in order to flare. Still, the ROD doesn’t look that high that the front section should just break off Hop![]()
JetPhotos: https://www.jetphotos.com/photographer/98880
Airliners.net: http://www.airliners.net/user/Bobbejaan/profile/photos
- Too Tousand
As far as I know most military aircraft are stressed for at least 9g.Roo1valk wrote: ↑Mon Jan 28, 2019 11:38 amNot sure if it's mentioned in the report, but on another forum they say the airframe is limited to 4G and the impact was at 7.4GsJack Welles wrote: ↑Sun Jan 27, 2019 11:28 amIn that video it looks as simple as that, when the main wheels touched down the front half of the aerie simply fell off!Hop Harrigan wrote: ↑Sun Jan 27, 2019 9:28 amMy guess is that with all that whiteness the pilot didn’t even see the ground in order to flare. Still, the ROD doesn’t look that high that the front section should just break off Hop![]()
The published load limit is for manoeuvre loads. The actual G-loading during gusts or (certification case) heavy landing may be higher, but will be included in the design.
I also wonder where the CG was during the landing.
- Fife Thousand feet
That may be true for fighters. Bombers typically have much lower G ratings - especially when loaded. For example, the closest US equivalent would probably be the B-1B, which has a G limit of 2.8G with full load.
- Tree Tousand
Not sure how credible this site is, but it lists the G-limit of the Tu-22M at +3.5g
http://black-shark.wikidot.com/tu-22
