Bushbaby Down at Petit - 2019-01-27
Anton Nel
Has liked: 23 times
Been liked: 37 times
Unread post by Anton Nel » Sun Jan 27, 2019 2:15 pm
I got some unconfirmed reports of a Bushbaby that had a misfortune at Petit. Apparently all okay.
Anton Nel
Has liked: 225 times
Been liked: 147 times
Re: Bushbaby Down at Petit - 2019-01-27
Unread post by Ugly Duckling » Sun Jan 27, 2019 2:48 pm
We flew over it on returning to Petit. Nosed over in the plowed field to the east of 03. Pilot & pax been for a check up.
Aircraft recovered after approval from CAA.
Has liked: 47 times
Been liked: 39 times
Unread post by V5 - LEO » Sun Jan 27, 2019 4:11 pm
....Hugo, Stefan kom in, julle ok???
Dobbs
Has liked: 12 times
Been liked: 16 times
Unread post by Dobbs » Sun Jan 27, 2019 5:15 pm
They are fine, CAA notified, so probably still busy with recovery and paperwork etc.
Anton Nel
Has liked: 23 times
Unread post by Anton Nel » Sun Jan 27, 2019 5:43 pm
They are fine, ....
Glad all is okay.
Anton Nel
Been liked: 501 times
Unread post by Bearcat » Sun Jan 27, 2019 5:46 pm
Which Bushbaby was it ?
Has liked: 270 times
Been liked: 269 times
Unread post by jimdavis » Sun Jan 27, 2019 5:53 pm
Why did they put down in a ploughed field?
Dobbs
Has liked: 12 times
Unread post by Dobbs » Sun Jan 27, 2019 6:07 pm
Jim, unless you know more than you are letting on, was there an alternative to the ploughed field?🤔
Unread post by Ugly Duckling » Sun Jan 27, 2019 6:23 pm
https://www.avcom.co.za/phpBB3/viewtopi ... 3#p2012554
He was 200 meters from 03.
I would consider carb ice as a factor if the engine has a carb.
Dobbs
Has liked: 12 times
Unread post by Dobbs » Sun Jan 27, 2019 6:30 pm
Thank U D, The first thought that crossed my mind - had he tried to make the runway, would he have been stretching the glide with a possible worse outcome.
Edit - was not a VW it was a UL260
Unread post by jimdavis » Sun Jan 27, 2019 7:09 pm
Ha ha ha, Dobbs, I think you are the one with the inside knowledge. Who said he had an engine failure? :lol:
Induna
Closest Airfield: FASD
Has liked: 12 times
Unread post by Induna » Sun Jan 27, 2019 7:14 pm
The UL is fuel injected, so no carb ice then.
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
bobthebuilder
Unread post by bobthebuilder » Sun Jan 27, 2019 7:15 pm
You don't have too many options but ploughed, or corn fields around Petit, depending on the time of the year. You have more forced lob options available at Petit than you would at, say Rand or Brakpan. It's definitely not an unsafe environment.
Dobbs
Has liked: 12 times
Unread post by Dobbs » Sun Jan 27, 2019 8:50 pm
Stefan from Bushbaby has provided some info on the accident / incident, and confirmed that it was engine failure. Probably too early for anything definitive, but nothing obvious.
Rotor kop
Closest Airfield: OR Thambo
Has liked: 91 times
Been liked: 13 times
Unread post by Rotor kop » Sun Jan 27, 2019 9:26 pm
Powerlines, big blue gum trees, a brick factory, houses etc. Only a reasonably safe environment if you are in the right place when things go wrong.
