Rwy 16 active in FACT?
Fralk
Closest Airfield: FASH-SFC
Unread post by Fralk » Thu Feb 07, 2019 10:28 am
ATIS advises: Rwy 19 blocked advise if not able to use Rwy 16. Anyone know the reason for this?
Would be interesting to see the A340, 747 and A350 that are inbound land on such a short runway.
Fralk
Re: Rwy 16 active in FACT?
Unread post by Fralk » Thu Feb 07, 2019 10:29 am
Lufthansa A340 holding over RIV
Fralk
Unread post by Fralk » Thu Feb 07, 2019 10:30 am
BA747 holding over ERDAS
Fralk
Unread post by Fralk » Thu Feb 07, 2019 10:33 am
A lot of activity at the airport
Deanw
Been liked: 78 times
Unread post by Deanw » Thu Feb 07, 2019 10:33 am
Qatar and Lufthansa also holding.
http://www.SAairforce.co.za
Chopperone
Flaps set for Take off
Unread post by Chopperone » Thu Feb 07, 2019 10:36 am
2 fire trucks threshold 01. Second hand info.
Fralk
Unread post by Fralk » Thu Feb 07, 2019 10:45 am
On FR24 it seemed like taxiway Charlie. Rwy 19 open again.
Multirotordronepilot
Has liked: 35 times
Been liked: 54 times
Unread post by Multirotordronepilot » Thu Feb 07, 2019 10:46 am
PC12 again :D flat wheel again :D
Trevor
Defense Contractor/Test Pilot
Commercial pilot,Instructor
Responsible Person Aircraft
TopRC HawkerHunter
JetLegend ViperJet
BVM F80 ShootingStar
1/3 J3 Cub
ZS-VVR
Deanw
Unread post by Deanw » Thu Feb 07, 2019 10:46 am
Runway seems to be open again. :D
RVator
Engine Started
Unread post by RVator » Thu Feb 07, 2019 2:19 pm
Red Cross Air Mercy PC12 came to a standstill on Runway 19 just short of Charlie.
I was on D1 doing hover practice.
Most impressive was the Mango 737 stuck at the hold of 19 that did a 180 degree turn and then
took off from RWY 16. Kudos to those guys for quick thinking.
swpurvis
Closest Airfield: jhb
Unread post by swpurvis » Fri Feb 08, 2019 7:21 am
I know the crew of that Mango flight very well. :lol:
Diesel-3
Straight and Level
Unread post by Diesel-3 » Fri Feb 08, 2019 10:17 am
I doubt there was any quick thinking involved. The crew would have looked at the numbers, run a calculation to see if they were legal and the a/c performance was suitable.. Im sure they followed SOP...
longpete
Straight and Level
Unread post by longpete » Fri Feb 08, 2019 10:59 am
Otherwise known as quick thinking ;)
Hunter
Taxiing
Closest Airfield: Morningstar
Unread post by Hunter » Fri Feb 08, 2019 2:31 pm
:D
Wynand Britz
ZS-DVA Cherokee 235
Adventures of a Rookie Pilot
Youtube Channel : https://www.youtube.com/user/wynandjnr
ddevos
Closest Airfield: FAVV
Unread post by ddevos » Fri Feb 15, 2019 10:41 am
An aircraft with a flat tyre stuck on a runway is one thing, but airliners being put in a holding pattern due to a broken down vehicle on a runway is a bit crazy, as has happened to us on 1 February. We were due to land ten minutes early, but ended up landing ten minutes late on rwy 16, as did a few other airliners behind us.
Dirk de Vos
