Bombardier CL601 Challenger crash in Mexico
Jasondn78
Left downwind (unmanned)
Closest Airfield: FAPE
Unread post by Jasondn78 » Mon May 06, 2019 9:57 pm
https://www.mirror.co.uk/news/world-new ... 4-15006183
This has been a terrible week.
This crash doesn’t give many clues as to what happened here. Confusing pax numbers. 18 on flight and 14 died. No further report of the other 4 pax.
Dragon
Returning to aircraft
Has liked: 69 times
Re: Bombardier CL601 Challenger crash in Mexico
Unread post by Dragon » Tue May 07, 2019 12:05 am
If I have to speculate based on the one alleged and unconfirmed pic I have seen, it's just sitting there in plan form with no visible scrape marks leading to it. Looks as if it spun in from above except it can't be because I can't see any rotation, and there's barely any forward speed after impact- so it looks to me like very slow speed very high rate of descent. Deep stall all the way down? Seems unlikely-but what else?
Dragon
Has liked: 69 times
Unread post by Dragon » Tue May 07, 2019 12:43 am
Nobody walked away from this one, they just got the pax numbers wrong.
Jasondn78
Unread post by Jasondn78 » Tue May 07, 2019 5:20 am
Looks like it went straight in.
No Fly No More
Unread post by No Fly No More » Tue May 07, 2019 7:33 am
My theory - he was too low for the mountains, realised too late, pulled up sharply and stalled it in. Boom!
Reports say 10 + 3. No survivors. Sad.
Dobbs
Has liked: 10 times
Been liked: 11 times
Unread post by Dobbs » Tue May 07, 2019 7:46 am
Must be some serious mountains there if his problems started at around 38 000 ft :shock:
Air Hog
Priming
Unread post by Air Hog » Tue May 07, 2019 8:03 am
Minus 20160 fpm, is this at all possible?
Has liked: 179 times
Been liked: 83 times
Unread post by Ray W » Tue May 07, 2019 8:09 am
That looks like his rate of descent to me - maybe a structural failure of some sort ?
Stephan van Tonder
Closest Airfield: Petit
Unread post by Stephan van Tonder » Tue May 07, 2019 8:32 am
The picture though has all the major parts accounted for?. Wings are both there. Tailplane is there. Nose was there albeit burnt out.
Jasondn78
Unread post by Jasondn78 » Tue May 07, 2019 9:08 am
Yeah, a plane coming down at a 90 degree nose down doesn't leave a wreckage that is even remotely distinguishable as a plane. Judging by the wreckage so neatly laid out, it looks like it was a low and slow impact.
Something is not adding up here.
Dobbs
Has liked: 10 times
Unread post by Dobbs » Tue May 07, 2019 9:27 am
At that descent rate and that attitude on impact - would one possiblity not be a deep stall?
These users liked the author Dobbs for the post:
Pink Panther
738
Flaps set for Take off
Unread post by 738 » Tue May 07, 2019 9:44 am
Moderators Message:
Off-topic and argumentative post deleted.
Keith Quixley
Unread post by Keith Quixley » Tue May 07, 2019 9:57 am
How much stock can you place in that last bit of Flightradar data? What is coverage like in the area and could that be interpolation in the absence of actual data being relayed?
Keith Windsor WcRostie Quixley (in case you were wondering)
Warloc67
Rotating
Unread post by Warloc67 » Tue May 07, 2019 10:58 am
18 on a CL601, seems it was high density config, not usual for a VIP aircraft?
Safety is not negotiable!
Sea Rescue
Been liked: 22 times
Unread post by Sea Rescue » Tue May 07, 2019 6:08 pm
Hi Dobbs,
I think you are on the nail, as a deep stall leaves exactly that very same "footprint" on the ground. I lost two friends in a similar accident, except there were no pax on board. They "played" around with a business Jet, lost it too close to the ground for an easy recovery - then as is human, pulled back on the stick in an attempt to "force" a recovery and hit the ground exactly as you see the Challenger did.
From nose to tail, all of it was there - when the cabin door popped open and slammed down, most of the coffee cups shot out of the galley and ended up in the grass about 30 meters away. The engines simply tore off, hit the ground and left a wheelbarrow full of turbine blades in a heap of metal. I still have one blade as a key ring. But for the fact that I had an important appointment with a customer and could not make the flight - I walked away.
Such is how aviation can be at times ? I am positive that this Challenger, for whatever the reason, went down in the exact configuration which I have described above. In the crash I mentioned above the forward momentum was only enough to move the aircraft 4 meters forward from point of impact.
Sad, but true - I wonder what caused that flight attitude to arise ??
These users liked the author Sea Rescue for the post:
