Diamond down Dubai
tansg
Climbing Out
Closest Airfield: OMAA
Has liked: 22 times
Been liked: 25 times
Re: Diamond down Dubai
Unread post by tansg » Sun May 19, 2019 9:34 am
jimdavis wrote:
Sun May 19, 2019 8:17 am
tansg wrote:
Sun May 19, 2019 6:15 am
It was an Aerodrome Ground Lighting (AGL i.e. Papis) calibration on 30L which is the runway under rehabilitation so no other traffic on that runway so Wake Turbulence unlikely.
How far is it from 30R? Wake turbulence spreads out, and it can drift in a light wind.
Hi Jim 400m Spacing with 1900m stagger on the Thresholds with 30L 1900m further out than 30R
Has liked: 292 times
Been liked: 125 times
Unread post by Ray W » Sun May 19, 2019 2:44 pm
Do we know who the crew were yet ?
Tallies
Hee Hee I'm Flying
Unread post by Tallies » Sun May 19, 2019 2:55 pm
MemyselfandI wrote:
Sat May 18, 2019 7:49 pm
I'm sure he means 30.
I did indeed. Post edited to comply.
These users liked the author Tallies for the post:
Tallies
"Science flies you to the moon; religion flies you into buildings."- Victor Stenger (renowned contemporary physicist and philosopher)
MemyselfandI
Unread post by MemyselfandI » Sun May 19, 2019 4:36 pm
I only know the pilots name so far , David Phillips.
Beacon1
Climbing Out
Closest Airfield: FAOR and VHHH
Unread post by Beacon1 » Sun May 19, 2019 5:33 pm
With the construction going on at OMDB at the moment, it is in the NOTAMS that under fair weather conditions (can't remember them all off the top of my head) that they are conducting trial periods of reduced wake separation (obviously still at a safe legal distance), with that muggy air and a slight breeze that wake turbulence could hang around a bit longer than predicted). We encountered the aircraft ahead of ours wake the other night on approach, at 5.5NM. Heavy to heavy. From what has been reported I would suspect that wake turbulence may have played a role.
*edit just saw it was for 30L, that may make it unlikely then!
For those who believe in fairies,roll another one. As for me.... I'd still rather be flying :)
Dragon
Rolling from unmanned
Has liked: 97 times
Been liked: 37 times
Unread post by Dragon » Sun May 19, 2019 8:00 pm
Speculation is a bit off. Was not an ILS calibration. It was an Aerodrome Ground Lighting (AGL i.e. Papis) calibration on 30L which is the runway under rehabilitation so no other traffic on that runway so Wake Turbulence unlikely.
People tend to only think of it in the context of a runway. Sometimes even a 737 gets a quick jolt in the TMA from crossing wake perpendicularly. You can find it in the most unexpected places. Can one be sure there was no one remotely near in the previous 5+ mins
GRAHAMW
Closest Airfield: FAUL
Been liked: 17 times
Unread post by GRAHAMW » Sun May 19, 2019 8:10 pm
Friends of ours stepson, Fritz Venter was also a pilot on the plane.
Graham Wallbridge
Aquila
Unread post by Aquila » Thu May 23, 2019 6:26 pm
I’m not seeing that NOTAM as current right now, from what I recall there is usually a NOTAM active that indicates there are reduced wake trial separation in place between EK aircraft only. However I couldn’t find it active when I checked OMDB’s NOTAMs today...
Raccoon jet driver...
See Horizons!
GRAHAMW
Unread post by GRAHAMW » Thu May 23, 2019 7:05 pm
Honeywell employee killed in Dubai plane crash is named
https://www.thenational.ae/uae/honeywel ... d-1.864930
Graham Wallbridge
GRAHAMW
Unread post by GRAHAMW » Tue May 28, 2019 8:32 am
A plane that crashed near Dubai's International Airport, killing four people, may have been hit by turbulence from the wake of another aircraft, an initial report has said.
https://www.bbc.com/news/uk-england-48421477
Graham Wallbridge
Iceberg
Has liked: 26 times
Been liked: 41 times
Unread post by Iceberg » Tue May 28, 2019 8:36 am
Avcom speculation spot on then...
These users liked the author Iceberg for the post:
The sky is not the limit....
ZS-MDK
Karl Eschberger
tansg
Climbing Out
Has liked: 22 times
Unread post by tansg » Tue May 28, 2019 8:40 am
snoopy
Has liked: 35 times
Been liked: 54 times
Unread post by snoopy » Thu Jun 06, 2019 2:03 pm
PIC was a former RAF wing commander (ATC) with 20 years RAF service, and civilian Com pilot. R.I.P
Vivere come se mai dovessimo morire
Has liked: 252 times
Been liked: 183 times
Unread post by Ugly Duckling » Fri Jun 07, 2019 11:14 am
Typo :shock:
It had been carrying out an approach to runway 30L which runs parallel to 30R.
The two runways are separated by just 380m although the threshold of 30R is displaced some 1,900m beyond of that of 30R.
Has liked: 298 times
Been liked: 308 times
Unread post by jimdavis » Fri Jun 07, 2019 12:09 pm
Typo :shock:
Where Paulus?
