GARMIN emergency autoland
ddevos
Closest Airfield: FAVV
Been liked: 46 times
Re: GARMIN emergency autoland
Unread post by ddevos » Tue Nov 05, 2019 5:53 pm
Vogoff wrote:
Tue Nov 05, 2019 1:11 pm
Which means it presents yet another hazard for the unwary pilot: taking off into bad weather thinking the autoland function will be able to get you down regardless of the weather at the destination.
Next challenge for Garmin: get the system to access weather info automatically for the planned flight and prevent the engine from starting if the weather is too bad. :wink:
These users liked the author ddevos for the post:
Mustang
Dirk de Vos
Mustang
Stall training
Closest Airfield: FATP
Has liked: 166 times
Been liked: 33 times
Unread post by Mustang » Tue Nov 05, 2019 7:34 pm
I once had to tell a CPL that he was going to kill himself and his passenger as radar showed red from Gariep up to Cape Town and he still wanted to fly. The weather was also closing quickly over us at Tempé and he wanted to get into the air quickly. The result was that he over primed the engine of the aeroplane and the air filter caught fire. I put out the burning filter with halon and then he regarded the incident as a sign that they should rather drive.
I concur with DdeVos.
"Aviation is a passion towards greater achievement in life!" - Júlíus Kloków (Mustang)
PO
Closest Airfield: H2Oklf
Has liked: 42 times
Been liked: 10 times
Unread post by PO » Tue Nov 05, 2019 8:50 pm
Captain Gyro wrote:
Sun Nov 03, 2019 5:06 pm
All fine and well when things are going well, but this system won't work after system failures, in remote areas where there is no where to land, in fuel exhaustion scenarios, or with any autoflight or mechanical malfunctions. Great for pilot incapacitation if the aircraft is within 200nm of a suitable airfield (according to Garmin) though.
Future embedded AI capability should take care of (some of) that, better and more proactive than a human. (Eg it would be easy to prevent 'fuel exhaustion scenarios' etc)
MTex
Has liked: 35 times
Unread post by MTex » Fri Nov 08, 2019 9:27 pm
Brilliant
