Runaway Trim: American Eagle Flight’s Emergency
John.com
Closest Airfield: Aeroden
Has liked: 21 times
Been liked: 17 times
Unread post by John.com » Sat Nov 09, 2019 6:21 pm
Chilling Air Traffic Control Audio of American Eagle Flight’s Emergency Landing After Runaway Trim
Credit: View from the Wing
On Wednesday American Airlines flight AA4439 from Atlanta to New York LaGuardia, an Embraer ERJ-175 (large regional jet) operated by Republic Airways, suffered runaway trim during climb out. “Runaway trim” became a well-known phenomenon over the last year as it’s associated with both Boeing 737 MAX crashes.
Listening to the air traffic control – the pilots and ATC both did an excellent job – is eerie. Thank goodness everyone made it safely back to Atlanta. They stopped for a visual inspection by emergency crew before returning to gate T11.
These users liked the author John.com for the post (total 2):
Capt. KyleERNIE
John Comley
Walter105
Has liked: 51 times
Been liked: 99 times
Re: Runaway Trim: American Eagle Flight’s Emergency
Unread post by Walter105 » Sun Nov 10, 2019 5:56 pm
Pretty crappy callsign, Brickyard....
Well done to the crew, but in the end it seems they just switched out the flight control system to direct law and transferred control to the FO as his controls were seemingly working fine at that point.
Any ERJ175 pilots here that could explain how that would have worked? Why direct law? How come the runaway trim could only affect the captain's controls?
Slick
Flaps set for Take off
Has liked: 24 times
Unread post by Slick » Mon Nov 11, 2019 9:58 am
I feel like they (and us) are assuming that just because they regained control, that they carried out the correct actions to solve the situation. It is quite possible that changing modes and also control, were completely unnecessary. They admitted to the Delta pilot that they didn't action the QRH, and then almost as a side note of their last actions, they mention that they pressed the Pitch System Cutout Buttons which is probably what their memory items and QRH would've told them to do in the first place. I find it highly unlikely that they would've had to go around the QRH (which they didn't action) in order to solve the problem.
Zulu01
Closest Airfield: KGSO
Unread post by Zulu01 » Mon Nov 18, 2019 7:21 am
Based in Indianapolis, where the speedway is called the Brickyard, because of one yard of bricks in front of pits.
Rick Cockcroft
Former GPL and instructor
PPL
RC Novice
Walter105
Has liked: 51 times
Unread post by Walter105 » Mon Nov 18, 2019 9:06 am
That adds some context thanks. Still a crappy callsign for an airline though.
Thermalator
Has liked: 21 times
Been liked: 33 times
Unread post by Thermalator » Mon Nov 18, 2019 10:21 am
You just had a classic Aviate Navigate Comunicate issue & some twat purporting to help, tells you to read the QRH #-o FO
info junkie
Baggie
Mags Dead Cut
Has liked: 13 times
Unread post by Baggie » Mon Nov 18, 2019 11:38 am
IIRC. The speedway track in Indianapolis was originally laid with bricks/cobblestones. When it was upgraded and re-profiled for safety reasons it was decided to leave a 1 yard wide strip of the old brick surface at the start/finish line for nostalgic reasons.
The crappiness of the callsign is in the ear of the listener. There are some others out there as well - “Cactus” springs to mind (Sully’s callsign if I remember correctly.😉
Zulu01
Unread post by Zulu01 » Mon Nov 18, 2019 5:38 pm
Cactus was the call sign for American West , and later US Air based out of Phoenix Az 😂
When they merged with American Airlines , the call sign became American
Rick Cockcroft
PPL
RC Novice
Walter105
Has liked: 51 times
Unread post by Walter105 » Mon Nov 18, 2019 10:36 pm
IINM ValuJet used to have callsign Critter. :)
Back to my original question though...
