Crash Springs
FoxTROT
Been liked: 10 times
Re: Crash Springs
Unread post by FoxTROT » Mon Nov 11, 2019 12:27 pm
Glide approach gone wrong?
These users liked the author FoxTROT for the post (total 2):
HunterNo Fly No More
Mikemccrsa
Stall training
Has liked: 9 times
Re: Crash Springs
Unread post by Mikemccrsa » Mon Nov 11, 2019 1:08 pm
richard C wrote:
Mon Nov 11, 2019 11:35 am
Do Piper pilots pull the carb-heat on downwind and base ? Always ?
I know that Jim talks about the superior design of the Piper because the carb continually scavenges heat from the engine near which it was cleverly placed, but does that effect the training ?
I was definitely taught to use the carb heat on downwind and base, close on short final in preparation for a go-around.
Christo
Has liked: 46 times
Been liked: 66 times
Re: Crash Springs
Unread post by Christo » Mon Nov 11, 2019 1:12 pm
my nemesis on PPL training. Kept forgetting to switch it off.
Has liked: 650 times
Been liked: 209 times
Re: Crash Springs
Unread post by ACE MAN » Mon Nov 11, 2019 1:36 pm
There is a home camera video on social media , basically landing short. Might just be me but I have flown most my light aircraft flying over the last 30 years in that region in all varying weather and never had carb icing? Mostly with O320 engines. A good friend of mine was killed just a block back from today’s accident while he was a passenger in a BE23 off rwy 21, hot high and tailwind takeoff. I was the one to take the call at JNB ATC. So it would appear today’s is an engine failure if sorts.
These users liked the author ACE MAN for the post:
Lazy duck
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Kibim
Closest Airfield: FAOI
Has liked: 16 times
Been liked: 34 times
Re: Crash Springs
Unread post by Kibim » Mon Nov 11, 2019 3:38 pm
Lets hope it didn't suffer the same fate at it's cousin, ZS-EXV did in 2016, catastrophic engine failure. Unfortunately the instructor and student were not so lucky on that occasion.
Brendan Marsay
ZS-OEM : Grob 109
Hunter
Closest Airfield: Morningstar
Has liked: 35 times
Been liked: 12 times
Re: Crash Springs
Unread post by Hunter » Mon Nov 11, 2019 3:44 pm
Part of my drills yes.
Wynand Britz
ZS-DVA Cherokee 235
Adventures of a Rookie Pilot
Youtube Channel : https://www.youtube.com/user/wynandjnr
Re: Crash Springs
Unread post by ACE MAN » Mon Nov 11, 2019 3:49 pm
And EXO ! I did 50% of my PPL on that at FASI!
My Question here to Jim or anyone else who has extensive hours (2000hr plus) on O320’s - have you EVER had carb ice that is so bad that the engine has failed? To have it at the point where you need to add power on the approach is extremely unforgiving.
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Romeo E.T.
Has liked: 32 times
Been liked: 255 times
Re: Crash Springs
Unread post by Romeo E.T. » Mon Nov 11, 2019 5:23 pm
over 3000 hrs on O320's and O360's
not once experienced carb icing
have however heard of the mythical inducing carb icing , when applying carb heat, but not self experienced or heard of
The worst I have ever encountered is a momentarily spluttering engine (Cessna) which I , at the time, I explained to myself, as partial carb icing being cleared and ingested thru the engine.
but never on a Piper (touch wood)
Didn't this early morning start of very moist (humid) after last nights weather that passed thru (mainly north of Gauteng) ?
These users liked the author Romeo E.T. for the post (total 3):
olie4ACE MANRotor kop
Romeo E.T.
Has liked: 32 times
Re: Crash Springs
Unread post by Romeo E.T. » Mon Nov 11, 2019 5:33 pm
PJL wrote:
Mon Nov 11, 2019 11:53 am
I was taught when turning base. I am so glad that my aerie is fuel injected!!
PJL
Yes...me too (mainly instructed on PA28's
Always taught my students the application of carb heat with the reduction of power on base leg.
Always taught my students to close carb heat once established on final approach.
Taught the carb heat mainly as an accepted procedure, rather than any actual evidence or occurance.
without a TAT probe in the throttle body of the carburetor, it is a "hit and miss" affair on whether to use carb heat or if the use of carb heat might actually raise the temperature into the carb icing range
Remember an idling engine produces very little heat to significantly "MELT" any carb icing, thus carb heat should be deployed whilst the engine is producing heat (power), before reduction of power
These users liked the author Romeo E.T. for the post (total 5):
Ugly DucklingACE MANapollo11jimdavisrichard C
savas
Been liked: 44 times
Re: Crash Springs
Unread post by savas » Mon Nov 11, 2019 5:54 pm
Carb heat should be applied ok downwind, base then off as one turns finals- in my opinion
spokes
Climbing Out
Closest Airfield: Siver Creek
Been liked: 76 times
Re: Crash Springs
Unread post by spokes » Mon Nov 11, 2019 6:02 pm
Pipers mainly use Lycomings and they have the carburettor in the oil sump to prevent ice forming. I have had ice in a Tripacer out of Rustenburg on the climb out but a dash of carb heat and then some splutter and all was fine again.
Has liked: 678 times
Been liked: 817 times
Re: Crash Springs
Unread post by jimdavis » Mon Nov 11, 2019 10:27 pm
I am with you Schultzie I have NEVER experienced airborne carb icing on an O320 or an O360.
However, taxying out on the first flight of the day with a cold engine and wet grass - YES it is very common - and mostly goes unnoticed. The pupe or pilot just adds a bit more power. You will notice it if you throttle fully back, then you realise the engine idles too slowly, or even wants to die.
After five minutes, or less, of ground running the sump has warmed sufficiently to warm the throttle body and that's the end of any ice.
So, no - I really can't support the carb icing theory for this accident.
These users liked the author jimdavis for the post (total 2):
Rotor kopACE MAN
homebuilt
Closest Airfield: FAEL
Been liked: 35 times
Re: Crash Springs
Unread post by homebuilt » Tue Nov 12, 2019 8:57 am
If the majority of experienced pilots think carb icing is NOT to blame what then about this scenario. Firstly I dont know the field from a bar of soap, circuit size or altitude or whether the pilot and pupe were flying circuits or had just returned from a cross country but what if the pilot flying selected the incorrect tank ( the emptier on of the two) on downwind and the fuel pipe ported on base to final turn leaving them on finals with a windmilling prop. By the time one had a chance to trouble shoot the aircraft would have been low and short of the field.
BigglesSA
Has liked: 30 times
Re: Crash Springs
Unread post by BigglesSA » Tue Nov 12, 2019 9:02 am
VID-20191111-WA0004.mp4
Seems to be coming in very steep?
Groetnis
Francois Gouws
Has liked: 240 times
Been liked: 256 times
Re: Crash Springs
Unread post by richard C » Tue Nov 12, 2019 9:29 am
Wow - not much of a flare, lucky they were not more seriously hurt.
I wonder if they chose to hit the road hard, instead of the concrete fence structure more slowly ? If so, they did a good job - they flew into the crash and walked away.
These users liked the author richard C for the post:
Grant all equity and dignity.
