ZS-FHC down 2020_03_08?
- Closest Airfield: DFFD
- Has liked: 169 times
- Been liked: 81 times
I just received some pictures on a whatsapp group, I don't see any other topic here
Ralph M Wigzell.
My Dave Clarks cost me R200 when 1 ZAR = 1 USD
Hindsight is what you see from the tailgunner position.
Re: ZS-FHC down 2020_03_08?
This is one of the pictures, since they are not mine I'm not sure if the owner will object, if they do I will have to take it down.
Ralph M Wigzell.
- Rolling
- Closest Airfield: Pretoria
- Has liked: 0
- Been liked: 1 time
Hi power accident... what broke the windscreen? Birdstrike?
- These users liked the author Tango Romeo for the post:
- Erika
Thomas Robbertse
1994 Grumman Tiger AG-5B
Can anyone confirm if this plane used to be operated by Border Flying Club in the 80s?
Ralph M Wigzell.
- thirty thousand
- Has liked: 322 times
- Been liked: 1891 times
- Niner Tousand
- Closest Airfield: FAJS
- Has liked: 37 times
- Been liked: 279 times
if the "THEORY" is correct, then the forward bent prop means it was under considerable power when it first struck the ground ?
Apart from the buckled firewall, this should be a repairable option ....except for the firwall ?
- Fower Tousand
- Closest Airfield: FACT
- Has liked: 96 times
- Been liked: 88 times
From someone at the scene I can share that there was too much air in the fuel tanks...
Jacques Taljard: Zero-Ate-Two Niner-4-Wun Seven-Zero-Sex-Too
- Niner Tousand
OUCH
Also looks like the wing is pretty messed up.
Ralph M Wigzell.
- Forgot to remove the chocks!
- Closest Airfield: FAGC
- Has liked: 2 times
- Been liked: 33 times
for a Flying Training Organisations aircraft - NOT GOOD !
- These users liked the author grounded for the post:
- Hans
- Seven Thousand
- Has liked: 725 times
- Been liked: 688 times
Top structure is from the ivory tower in Midrand
- Rotating
- Closest Airfield: YBAF
- Has liked: 51 times
- Been liked: 79 times
Did she run out of juice in the cruise or close to an airfield? Location of 'forced landing' site?
GR III C210 B1900 YDKWYDK
- Closest Airfield: FAGM
- Has liked: 423 times
- Been liked: 242 times
Hang on.
Prop tips being bent would suggest that engine running at impact. Does not gel with the fuel starvation rumour?
So what was it ?
So what was it ?
- These users liked the author Mrb13676 for the post (total 3):
- Rotor kop • BigglesSA • Dragon
Mike Blackburn
ZU-IBM - Sling4 Turbo s/n 009
- 10000 and still climbing
- Closest Airfield: FAGG
- Has liked: 922 times
- Been liked: 1155 times
That prop bending rule is far from infallible. But on the same topic, I seem to remember this 180 had been fitted with a CSU. Anyone know it that's correct? It was never a good idea on the 180s - it simply added weight, maintenance costs and seemed to degrade performance.
- These users liked the author jimdavis for the post:
- STR82TH
