Light aircraft down Pretoria, ZS-UKU KR2
- Pre-take off checks
- Closest Airfield: Springs
- Has liked: 11 times
- Been liked: 7 times
Re: Light aircraft down Pretoria, ZS-UKU KR2
The main spar failed by photos posted. A number of incidents could have contributed. Hard landings, flutter , a few gs in flight, turbulence. Holes in the cheese lined up. All those exceedance inspections on all private aircraft should be carried out as per manufacturers manual on every 100 hour . They might not be reported. Even every 50 hours in the case of experimental.
Experimental aeries might not be as specific so some criteria may be missed.
- Hee Hee I'm Flying
- Closest Airfield: FAPX
- Has liked: 17 times
- Been liked: 57 times
CAA report
- Too Tousand
- Closest Airfield: FAOR
- Has liked: 482 times
- Been liked: 732 times
Really good report - says it all . Not the first such failure in KR2s.
- Has liked: 13 times
- Been liked: 91 times
Pls can someone explain to me how the residual moment on the aileron works...
I see from he photo of the aileron that the moment appears to be being measured from the hinge line to the end of the aileron. I would have thought that the moment would be measured from the hinge line to, either the CG of the aileron or to the Centre of Pressure of the aileron?
What am I not understanding?
Thanks
Hop
Thanks
Hop
- These users liked the author Hop Harrigan for the post:
- jvg075
- Closest Airfield: Cab
- Has liked: 123 times
- Been liked: 245 times
Unfortunately I'm not somewhere I can create a sketch for you, this is always easier to explain with a visual aid. Hope my explanation works...Pls can someone explain to me how the residual moment on the aileron works...
The key here is the "moment", ie the force multiplied by the distance. Moment = force x distance. (FWIW there is a slight error in the report - the units should be kg.mm, not kg/mm. Purists might also object to using mass instead of weight (force), but under 1G static loading the outcome is not affected)
If the CG is on the hinge line, the distance is zero, and hence the moment is zero. Moment = force x distance = force x 0 = 0.
If the CG is not on the hinge line, then it will cause a moment around the hinge. Let's call in M1= F1 x d1, where F1 is the force (weight) and d1 is the distance between hinge line and CG. Let's assume it causes the aileron to hang trailing edge down (most common condition). In order to balance this horizontally, you'd have to counter it with an equal moment in the other direction. You can apply the balancing force anywhere, but it's convenient to do it somewhere where you can easily measure the distance, eg the trailing edge.
So to balance the moment, you apply a force up at the trailing edge, which you measure with a scale. You then know that the moment you have applied to counter the imbalance is M2 = F2 x D2. M2 is the reading on the scale, D2 is the distance from the trailing edge to the hinge. And for balance, M2 = M1.
The significance in this case is that the designer specified that the ailerons should be fully balanced (also known as zero balanced). M1 should be zero, M2 should be zero. The investigators have shown in their little test that the aileron was not zero balanced. The effect of the actual amount of imbalance is difficult to determine, but they have shown that it was not balanced, ie out of spec.
- These users liked the author StressMerchant for the post (total 3):
- jimdavis • Volo • AEH
Dweller on an errant planet
- Reaching altitude
- Closest Airfield: FAPE
- Has liked: 4 times
- Been liked: 2 times
Hi Hop
I reckon the aileron was supported at the hinge line and, with it in a horizontal position, the scale was used to determine the residual "weight" at the trailing edge (which should be zero if it were perfectly balanced and naturally in a horizontal position with no force applied to it). The measured 0.415 kg is multiplied by the 0.145m distance from the pivot line, then should be multiplied by accel due to gravity G (9.81 m/s^2) to determine the residual moment in Nm. I get 0.59 Nm. Remember a moment is actually a force x distance, and F = ma (Newton), where a = G in this instance.
To balance the aileron you would then need a mass of M kg with its CG at a distance D metres on the other side (front) of the hinge line such that (M x 9.81) x D = 0.59 Nm, since F = Ma. At least that's the way I see it.
Dave Louw
"The greatest enemy of knowledge is not ignorance, it is the illusion of knowledge" - Daniel J. Boorstin
- Reaching altitude
Apologies StressMerchant, I think we were typing at the same time, I didn't see your reply. I think we're essentially saying the same thing though, no?
Dave Louw
- 10000 and still climbing
- Closest Airfield: FAGG
- Has liked: 1849 times
- Been liked: 2443 times
Stressors, a question if I may: If the imbalance is exactly equal on both ailerons, and they are connected by rods which effectively have no play, would each act as an effective counterbalance for the other? I suspect this might be a theory thing that for some reason doesn't work so well in practice.StressMerchant wrote: ↑Tue May 17, 2022 1:49 pmThe key here is the "moment", ie the force multiplied by the distance. Moment = force x distance. (FWIW there is a slight error in the report - the units should be kg.mm, not kg/mm. Purists might also object to using mass instead of weight (force), but under 1G static loading the outcome is not affected)
Jim
No, because an upset in roll has the reverse effect on each aileron and the one would aggravate the other rather than restore the upset.jimdavis wrote: ↑Tue May 17, 2022 2:33 pmStressors, a question if I may: If the imbalance is exactly equal on both ailerons, and they are connected by rods which effectively have no play, would each act as an effective counterbalance for the other? I suspect this might be a theory thing that for some reason doesn't work so well in practice.StressMerchant wrote: ↑Tue May 17, 2022 1:49 pmThe key here is the "moment", ie the force multiplied by the distance. Moment = force x distance. (FWIW there is a slight error in the report - the units should be kg.mm, not kg/mm. Purists might also object to using mass instead of weight (force), but under 1G static loading the outcome is not affected)
Jim
- These users liked the author Russell Phillips for the post (total 2):
- Jan • StressMerchant
- Too Tousand
- Closest Airfield: MOSSELBAAI
- Has liked: 35 times
- Been liked: 86 times
Thank y you for the explanations.
I have a question re figure 17: How does the bell crank or horn attach to the aileron? It seem so be just bonded in/on? I cannot see screws or other hardware in the figure.
I other words - if that was more sturdy would it maybe have survived the flutter?
- These users liked the author Jan for the post:
- NVR
Flying is about discipline!
AP325
AP325
- Steep Turn Right
- Closest Airfield: FAOH
- Has liked: 15 times
- Been liked: 40 times
Jan my understanding and experience with flutter is that nothing will last in a flutter. You need to stop it fast and the problem is that once you notice it - it is already in an advance stage of oscillation....
It will bent steel and shear composite like a toothpick...if the horn did not fail - the next in line would have...
Morné Nortier
ZU-IPH CX150
ZU-IVG C150
ZS-MWC C150
ZU-IOY X350
ZU-BFG Bushbaby
ZU-IPH CX150
ZU-IVG C150
ZS-MWC C150
ZU-IOY X350
ZU-BFG Bushbaby
There will be an article on flutter, and the surprising number of South African accidents caused by it, in SA Flyer at the end of this month (May 2022).
- These users liked the author jimdavis for the post (total 2):
- AEH • Johan Swakopmund
- Engine full power confirmed
- Has liked: 27 times
- Been liked: 26 times
A short while after this accident, and because of it, I re-tested my aileron mass balance. It was out on the RHS due to a slightly thicker layer of paint that was applied after the initial balancing, which was done prior to the final top coat layer. I have friese type ailerons with the mass balance in the leading edge, so the arm is very short. I don't have an external weight like that on Russel's KR1 (see video posted above). I fibre glassed in place onto the forward portion of the friese a few automotive wheel balance weights (the flat rectangular type with adhesive on the back, used on mag wheels I think). All of my control surfaces are 100% mass balanced.
I also never go anywhere near VNe, after all, I am a member of the LCC.
- These users liked the author KEO for the post (total 2):
- Jan • jimdavis
Brett Williams
Whisper X-350 ZU-TCC
- Too Tousand
- Closest Airfield: Chek Lap Kok VHHH
- Has liked: 103 times
- Been liked: 141 times
I agree, a well written report.
However since the cause of the accident was concluded to be flutter, it would have been good to see a more detailed account of how they arrived at this conclusion eg. analysis of the failure modes of the spar, aileron control connections, torsional cracking in wing skins etc.
“Post- accident visual examination of the right-wing spars was an indication of structural overload in both a positive and negative direction.” How was this indicated - the report doesn’t elaborate or provide evidence?
- These users liked the author Wingnutter for the post:
- Peregrine
"Pilots take no special joy in walking"
The top and bottom spar caps look identical at the failure point. Since they are also of identical size it makes sense that the loading was "symmetrical" (equal pos and negative g). Had it been a simple overload in one direction the cap that failed in compression would have looked different to the cap that failed in tension.
- These users liked the author Russell Phillips for the post (total 4):
- Wingnutter • StressMerchant • AEH • Jean Crous
