Light aircraft down Pretoria, ZS-UKU KR2
Golf Tango
Been liked: 34 times
Re: Light aircraft down Pretoria.
Unread post by Golf Tango » Mon Nov 01, 2021 3:34 pm
We were flipping some Pretoria Boys High boys the previous Friday at Kittyhawk. The gentleman killed in this accident was one of the pilots there, although he didn't flip any of them, he was flying the accident plane there. There was a thanks ceremony after and in the back ground the the deceased was doing all kinds of aerobatics in the KR2. Most of the guys (high time aerobatics pilots mostly) were amazed with how he was flying that plane as was I. Means we had never seen a KR2 flown like that 😱. I remarked to my colleagues that the airframe whistled nicely. Shame.
These users liked the author Golf Tango for the post (total 2):
jimdavisBackmarker
"I put my finger up and blocked out the whole earth, made me feel incredibly small" - Niel Armstrong
Golf Tango
Unread post by Golf Tango » Mon Nov 01, 2021 3:59 pm
The wreck landed in my friends sisters farm. The deceased was thrown clear of the aircraft likely during the break-up.
These users liked the author Golf Tango for the post:
xfiles
Vincent
Mags Dead Cut
Closest Airfield: Matsapha
Has liked: 22 times
Unread post by Vincent » Mon Nov 01, 2021 4:12 pm
wow... :shock:
These users liked the author Vincent for the post:
Volo
Theuns v V
Has liked: 23 times
Been liked: 368 times
Unread post by Theuns v V » Mon Nov 01, 2021 4:15 pm
Magtag that is total destruction :shock: :shock:
By the looks of the pattern can one assume that the impact was very vertical? hence not spread over a larger area
Has liked: 1849 times
Been liked: 2443 times
Unread post by jimdavis » Mon Nov 01, 2021 4:39 pm
Thanks Golf Tango. From what you say it sounds as if the pilot was possibly subjecting the airframe to loads for which it was not designed.
These users liked the author jimdavis for the post (total 6):
RudixJohan SwakopmundFranswmarkIIBackmarkerWout
markII
Unread post by markII » Mon Nov 01, 2021 5:00 pm
viewtopic.php?f=1&t=21071
Came across this thread.
WHEN IN DOUBT PULL OUT!!!!!
Mark
markII
Unread post by markII » Mon Nov 01, 2021 5:15 pm
These users liked the author markII for the post:
Rooster
Mark
Has liked: 1110 times
Been liked: 1165 times
Unread post by Ugly Duckling » Mon Nov 01, 2021 5:16 pm
The center section spar attached to the wing spar
Paul Sabatier
willieklanie
Closest Airfield: EGLL
Has liked: 26 times
Unread post by willieklanie » Mon Nov 01, 2021 5:23 pm
A couple of months ago I was in Nelspruit where the same Gentleman was test flying another converted KR 2 (converted to single seat with Jab3300).
It was low pass after low pass, full bore followed by pitch-ups and then other excessive manoeuvring. I was surprised to see how much such an airframe could withstand. (not flown within a normal test flight regime; didn't follow a logical pattern, was just hot-doggin it)
As a fellow aerobatic pilot i was wondering whether perhaps the pilot flying that particular day had become so tame with "g" forces or over-trusting of the design limits, or whether he was just that good that he knew the limits.
Very sad.
Rudix
Closest Airfield: Private on farm
Has liked: 23 times
Unread post by Rudix » Mon Nov 01, 2021 5:34 pm
Very sad.
I wonder if it was this flight?
savas
Been liked: 103 times
Unread post by savas » Mon Nov 01, 2021 6:02 pm
Very sad.
Even when I maidened a RC plane back in the day, I would keep it high at first for 1st flight, land check everything and then deem it safe to fly low!!
Theuns v V
Has liked: 23 times
Unread post by Theuns v V » Mon Nov 01, 2021 6:04 pm
By no means am I an engineer or test pilot but I recall when my plane was tested it was done rather gently at first and at hight if the donkey quit. It will be difficult to judge the G loads during those pull ups but I can se it being more than may be 3-4. As far as I know the wings should be load tested to 1.5 G of the flight category it will be used in. Wood is by far stronger then people thing and it will flex before breaking....if the glue is strong enough and there is a good propper glue surface joint.
Another thing I was wondering about, what is the VNE of the KR? If aeros was indeed done ,not saying it is so just speculating, maybe the speed buildup was to much for the airframe and as mentioned flutter could have occured. 8-[
Has liked: 551 times
Been liked: 456 times
Unread post by V5 - LEO » Mon Nov 01, 2021 6:11 pm
....was that really the "maiden" flight, what about the flights to proof she is airworthy for an ATF, or is that only after initial build and not rebuild / modifications?
These users liked the author V5 - LEO for the post:
Raffles
Theuns v V
Has liked: 23 times
Unread post by Theuns v V » Mon Nov 01, 2021 6:20 pm
I recall the original airframe was done in the late 70's ? I stand to be corrected but the glues back then were not as robust against aging as more modern epoxy systems are. With somthing like a spar where access to the internals is not good for inspection it may be a problem I recon.
That is why if someone asks me for an opinion of a wooden airframe where I can not see, feel and do a tap test I am rather hesitant if I konw older tipe glues were used. I am not saying the older glues are bad, just more need for proper inspection.
I have had ribs almost fall apart in my hand where the gussetes were held on only by the nails as the glue has become powdery and brittle
These users liked the author Theuns v V for the post:
flysouth
MLyons
Has liked: 17 times
Been liked: 68 times
Unread post by MLyons » Mon Nov 01, 2021 6:46 pm
:shock: :shock: #-o
You toucha my stuff, I breaka you face.
Idiot in search of a village........never mind - found it!
