southside
- Frequent AvComer
- Closest Airfield: around
Has liked:
6 times
Been liked:
556 times
Unread post
by southside » Thu Mar 24, 2022 9:09 pm
GeraldNagel wrote: ↑Thu Mar 24, 2022 7:04 pm
Another possibility perhaps? Pilot lost his licence when this pic became viral.
This looks very fake to me? Photoshopped? The screens are weirdly blurred, the overhead panels look like a picture out of flight simulator.
Maybe I am wrong, just looks dodgy.
- These users liked the author southside for the post (total 2):
- Dobbs • blesbok
GeraldNagel
- Tree Tousand
Has liked:
67 times
Been liked:
128 times
Unread post
by GeraldNagel » Thu Mar 24, 2022 9:38 pm
Just for you southside. I saw Santa Clause too but he was traveling at supersonic speed to deliver present to all little kids.
https://edition.cnn.com/travel/article/ ... index.html
- 10000 and still climbing
- Closest Airfield: FAGG
Has liked:
1849 times
Been liked:
2443 times
Unread post
by jimdavis » Thu Mar 24, 2022 10:15 pm
Raffles wrote: ↑Thu Mar 24, 2022 8:59 pm
Hop Harrigan wrote: ↑Thu Mar 24, 2022 7:21 pm
Can someone tell me what the stall speed would be at 29000’ pls?
Hop
For 65,000kg flaps up maneuver speed is approximately 210 knots indicated (Vref 40 + 70) but this is for lower altitude, The actual stall speed will be around 180 to 190 KIAS. I can't find the high altitude buffet speeds, I'll keep looking.
At a particular weight and configuration, is the indicated stall speed not the same at all altitudes?
- These users liked the author jimdavis for the post:
- Raffles
Look inside these books, or buy them at:
www.jimdavis.co.za.
foxbat
- See Helicopter in the distance
Has liked:
3 times
Been liked:
35 times
Unread post
by foxbat » Thu Mar 24, 2022 10:42 pm
jimdavis wrote: ↑Thu Mar 24, 2022 10:15 pm
Hop
Only if you assume that air is incompressible
Yes, No, Maybe, I don't Know, Can you repeat the question?
Eagles may soar, but weasles don't get sucked in jet engines!
Raffles
- Closest Airfield: DFFD
Has liked:
537 times
Been liked:
200 times
Unread post
by Raffles » Thu Mar 24, 2022 11:43 pm
Hop
Hello Jim,
The stall speed at high altitude ( > 20,0000 feet ) when flying at a high Mach number ( I guess > M0.5 ) will be higher due to compressibility effects. There is a fair explanation
here
Use this link for more search results.
https://searx.be/search?q=low+speed+buf ... ude+flight
I also use the NASA website a lot
www.nasa.gov, if I can find the topic, I will share it with everyone here.
- These users liked the author Raffles for the post (total 2):
- jimdavis • AEH
Ralph M Wigzell.
My Dave Clarks cost me R200 when 1 ZAR = 1 USD
Hindsight is what you see from the tailgunner position.
Airwayfreak
- Too Tousand
- Closest Airfield: FAJS
Has liked:
133 times
Been liked:
554 times
Unread post
by Airwayfreak » Thu Mar 24, 2022 11:56 pm
Stall speed increases due to compressibility.
PS: Sorry, I see Jim's question was answered
Be careful when following the masses. Sometimes the "m" is silent
Has liked:
1849 times
Been liked:
2443 times
Unread post
by jimdavis » Fri Mar 25, 2022 7:00 am
Raffles wrote: ↑Thu Mar 24, 2022 11:43 pm
Hello Jim,
here
Okay thanks Raffles, got it. It seems the shock wave causes the wing to stall at a lower angle of attack, and thus a higher TAS and IAS.
www.jimdavis.co.za.
wingnutzster
- Closest Airfield: FALA
Has liked:
7 times
Been liked:
67 times
Unread post
by wingnutzster » Fri Mar 25, 2022 8:31 am
I realize it's a little bit of a stretch but what about Mach Tuck? Mcrit for the 737NG series? The maximum authorized speed with Mach Trim inoperative is 0.74 Mach 480kts, the 'upset' here seems to have occurred dramatically and suddenly at around 450kts, mach trim failure? It's a rabbit hole because the discussion around Mcrit for the 737 is a long one with lots of maths and varying answers but is it at least plausible as something to tick off?
- These users liked the author wingnutzster for the post:
- StressMerchant
MadMacs
- Too Tousand
- Closest Airfield: Milkyway
Has liked:
654 times
Been liked:
146 times
Unread post
by MadMacs » Fri Mar 25, 2022 9:58 am
There have been many pressurization controller failures with the 737 and recently a Kalula B737 had to do an emergency decent into George, and as someone mentioned a controlled descent , it could have been an emergency descent gone wrong.
Denial ain’t a river in Egypt
Globemaster
- Post Take off checks
Has liked:
5 times
Been liked:
3 times
Unread post
by Globemaster » Fri Mar 25, 2022 10:14 am
There is the Possibility of the aircraft being shot down by a missile. Could also explain the sudden dive.
The missiles would be heat seeking at close proximity and would then take out the wing…
All systems are go!
Christo
- 8000 Tousand
Has liked:
106 times
Been liked:
188 times
Unread post
by Christo » Fri Mar 25, 2022 10:50 am
Globemaster wrote: ↑Fri Mar 25, 2022 10:14 am
At that altitude it's out of range for an Igla/stinger. Would have to be a proper SAM system
- These users liked the author Christo for the post:
- Globemaster
Morph
- Incipient Spin
- Closest Airfield: Morning Star
Has liked:
3 times
Been liked:
10 times
Unread post
by Morph » Fri Mar 25, 2022 11:07 am
Would the aircraft not then dive in flames?
Greg Perkins
Globemaster
Has liked:
5 times
Been liked:
3 times
Unread post
by Globemaster » Fri Mar 25, 2022 11:20 am
Morph wrote: ↑Fri Mar 25, 2022 11:07 am
Could well be, yes.
Another scenario could be a failure or seperation of the horizontal stabilizer. I hope they release the DFDR data so we can finally get closer to what happened.
All systems are go!
- Six Tousand
Has liked:
49 times
Been liked:
599 times
Unread post
by heisan » Fri Mar 25, 2022 11:35 am
Globemaster wrote: ↑Fri Mar 25, 2022 11:20 am
Could well be, yes.
If the video is accurate, then:
1) there would not be flames, as the air speed would be way too high for combustion.
2) a horizontal stabilizer is required to maintain a vertical dive (if the wings are still attached) - without the stabilizer it would tumble.
- These users liked the author heisan for the post:
- Pete
southside
- Frequent AvComer
Has liked:
6 times
Been liked:
556 times
Unread post
by southside » Fri Mar 25, 2022 12:20 pm
It seems I was wrong. Thank you Gerald.
