Pretty sure a swept wing will be stable in a vertical dive. Also some of the stabilizer will likely still be present. COG will be even more forward due to loss of mass far back on the fuselage. Lawn dart comes to mind...
Boeing 737 Crash in China 2022_03_21
- Too Tousand
- Closest Airfield: FASH
- Has liked: 66 times
- Been liked: 399 times
Re: Boeing 737 Crash in China 2022_03_21
- Closest Airfield: FAUL
- Has liked: 18 times
- Been liked: 82 times
China Eastern Airlines grounds 223 Boeing 737-800 aircraft after crash
https://edition.cnn.com/2022/03/24/busi ... ium=social
Graham Wallbridge
- Closest Airfield: DFFD
- Has liked: 537 times
- Been liked: 200 times
Update from AvHerald https://avherald.com/h?article=4f64be2f&opt=0
However someone made the following commentOn Mar 25th 2022 the CAAC reported in the 5th press conference, that the gear box of an engine as well as the main landing gear have been found and recovered. Some of the aircraft parts showed traces of fire. The CVR's memory chip is damaged and needs to be sent to the chip manufacturer for repair according to recommendation by the manufacturer. At this time there are no time estimates of when the data can be downloaded.
CAAC's press conference did not confirm that the CVR's memory chip was damaged. According to the conference recording, the question asked was "Is it true that decoding the black box data would take 10 to 15 days?"
The answer was that there were three conditions a black box can be found after a plane crash: (1) No damage to the black box; (2) Damage to black box casing but no damage to the memory chips; and (3) Damage to black box and memory chips. He mentioned that in the third case, the manufacturer would recommend sending the memory chips back for repair.
Finally he said that therefore, the time needed for data analysis cannot be determined at this time, because it would vary based on the condition of the recorders (which implies they are not certain of the CVR memory chip condition as of now).
In summary, the press conferences only confirmed damage to the CVR casing. They did not confirm the condition of the memory chips.
Adding to my previous comment:
Some websites posted excerpts of the press conference that only covered the 3rd possibility, which made it look like the memory chip was damaged. However this was not confirmed in the press conference.
I am a native Chinese speaker and I watched the press conference video.
Ralph M Wigzell.
My Dave Clarks cost me R200 when 1 ZAR = 1 USD
Hindsight is what you see from the tailgunner position.
- Too Tousand
- Closest Airfield: Milkyway
- Has liked: 654 times
- Been liked: 146 times
Do you remember that JAL B747 that had the aft pressure bulkhead fail and blow the tail off?Globemaster wrote: ↑Fri Mar 25, 2022 11:20 amCould well be, yes.Morph wrote: ↑Fri Mar 25, 2022 11:07 amWould the aircraft not then dive in flames?Globemaster wrote: ↑Fri Mar 25, 2022 10:14 amThere is the Possibility of the aircraft being shot down by a missile. Could also explain the sudden dive.
The missiles would be heat seeking at close proximity and would then take out the wing…
Another scenario could be a failure or seperation of the horizontal stabilizer. I hope they release the DFDR data so we can finally get closer to what happened.
Denial ain’t a river in Egypt
- Pre-take off checks
- Has liked: 3 times
- Been liked: 4 times
- See Helicopter in the distance
- Closest Airfield: Virginia KZN
- Has liked: 31 times
- Been liked: 18 times
The Swift Air 737 flight loosing part of it's dorsal and damaging the elevators came to mind when I saw this.
https://avcom.co.za/phpBB3/viewtopic.php?t=230047
There is an art . . . to flying. The knack lies in learning how to throw yourself at the ground and miss.
— Douglas Adams
— Douglas Adams
- Post Take off checks
- Has liked: 5 times
- Been liked: 3 times
Cool, thank you for the insight.Christo wrote: ↑Fri Mar 25, 2022 10:50 amAt that altitude it's out of range for an Igla/stinger. Would have to be a proper SAM systemGlobemaster wrote: ↑Fri Mar 25, 2022 10:14 amThere is the Possibility of the aircraft being shot down by a missile. Could also explain the sudden dive.
All systems are go!
JAL 123, just read up on it. The vertical stabilizer detached in that case. If the stabilizer were to detach, it would have disastrous consequences to Pitch attitude.MadMacs wrote: ↑Fri Mar 25, 2022 1:45 pmDo you remember that JAL B747 that had the aft pressure bulkhead fail and blow the tail off?Globemaster wrote: ↑Fri Mar 25, 2022 11:20 amCould well be, yes.
- These users liked the author Globemaster for the post (total 2):
- helishaun • MadMacs
All systems are go!
- Tree Tousand
- Closest Airfield: FAVV
- Has liked: 0
- Been liked: 143 times
I'm not sure what else they expected to see, with so much flames after the crash, it is rather obvious that there would have been traces of fire...On Mar 25th 2022 the CAAC reported in the 5th press conference, that the gear box of an engine as well as the main landing gear have been found and recovered. Some of the aircraft parts showed traces of fire. The CVR's memory chip is damaged and needs to be sent to the chip manufacturer for repair according to recommendation by the manufacturer. At this time there are no time estimates of when the data can be downloaded.
Dirk de Vos
- Aircraft in Hangar
- Closest Airfield: cape town
- Has liked: 20 times
- Closest Airfield: FALA
- Has liked: 7 times
- Been liked: 67 times
- 8000 Tousand
- Has liked: 106 times
- Been liked: 188 times
Not hard to imagine a 737 loosing parts going way past Vmowingnutzster wrote: ↑Fri Mar 25, 2022 11:20 pmHMMMM https://www.flyingmag.com/part-of-china ... rash-site/
- Fower Tousand
- Closest Airfield: FAKT+VHHH+FAPX
- Has liked: 1137 times
- Been liked: 438 times
There is some suicide talk now in the China media.
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Nomakhanjani
¯¯VAF¯¯
...and in local media,
I can list hundreds of crashes that were thought or said to be pilot suicide which turned out not to be.
Unless some damning evidence comes to light it really isn't on the table, so far it's just media hearsay. If it turns out to in fact be a case of pilot suicide then as rare as it is the already strained industry will have to carefully react, perhaps looking at new cockpit procedures in the event of such an attempt or go even deeper and take greater responsibility for the mental health of its crews. Pilot murder-suicide is the worst-case scenario I think, airplanes can be fixed, systems can be fixed.
- These users liked the author wingnutzster for the post (total 2):
- DVS • Tesla
- 10000 and still climbing
- Closest Airfield: FAGG
- Has liked: 1849 times
- Been liked: 2443 times
Hmmmm. It sounds as if there were three, or possibly even four, of them in the cockpit. This makes suicide unlikely unless someone used a gun.
- These users liked the author jimdavis for the post (total 2):
- wingnutzster • Raffles
