Inconceivable to think 133 souls and a mid-size airliner are now a littered smudge on a slope, looks like a horrible scene to investigate
....saw a program last night where a retired NTSB accident investigator alluded to this, his words, "though the footage is not clear, the image looks more like a missile than an airplane going in near vertical"Ugly Duckling wrote: ↑Tue Mar 22, 2022 8:30 amI can't verify the accuracy of the source of the image
If thats a true image, is it just me or does the vertical tail fin (rudder stabiliser) look a bit shorter than it should be???Ugly Duckling wrote: ↑Tue Mar 22, 2022 8:30 amI can't verify the accuracy of the source of the image
that image does not add up with what we know the crash aircraft looked like, no winglets visible, not the colors of China Eastern and there's a suspicious haze about it, I know a little bit about photo editing and image manipulation and this is very suspicious to me.Ugly Duckling wrote: ↑Tue Mar 22, 2022 8:30 amI can't verify the accuracy of the source of the image
Apart from that, where are the wing tips (as wingnutzster also mentioned)? If they came off on the way down, how did one end up right where the aircraft hit the ground? It seems to have been taken from the opposite side from where the video was taken. Also, a Google search on this image does not deliver any results, neither does it feature in a search on this crash. Where did this image come from, UD?Vincent wrote: ↑Tue Mar 22, 2022 9:27 amIf thats a true image, is it just me or does the vertical tail fin (rudder stabiliser) look a bit shorter than it should be???Ugly Duckling wrote: ↑Tue Mar 22, 2022 8:30 amI can't verify the accuracy of the source of the image![]()
There is a video of it doing the rounds on Facebook, this could be still from that video, i found it under Commercial Plane Loversddevos wrote: ↑Tue Mar 22, 2022 10:20 amApart from that, where are the wing tips (as wingnutzster also mentioned)? If they came off on the way down, how did one end up right where the aircraft hit the ground? It seems to have been taken from the opposite side from where the video was taken. Also, a Google search on this image does not deliver any results, neither does it feature in a search on this crash. Where did this image come from, UD?Vincent wrote: ↑Tue Mar 22, 2022 9:27 amIf thats a true image, is it just me or does the vertical tail fin (rudder stabiliser) look a bit shorter than it should be???Ugly Duckling wrote: ↑Tue Mar 22, 2022 8:30 amI can't verify the accuracy of the source of the image![]()
There have also been a couple of earlier B737 aircraft that had un-commanded full rudder deflection that caused hull losses.ACE MAN wrote: ↑Tue Mar 22, 2022 2:21 amI can’t recall but seem to remember a B737 incident/accident where the rudder trim was held in full deflection (it was mistaken for the flight deck door) till the point that the automation could no longer hold the desired path and let go. Imagine that is the case to the point the aircraft enters a hard rudder over and the vertical stab subsequently snaps off. Whatever it was it will be a hell of a ride. I do find these types of accident , that If it is a result of a pilot action , that the manufacturer takes the blame.
