Free Tip - maybe wrong forum
Francois Greeff
Hee Hee I'm Flying
Closest Airfield: Witbank
Unread post by Francois Greeff » Fri May 24, 2013 4:08 pm
Free, mahala, gratis, niks Just a tip when selling or buying equipment.
Hi guys
For you that don't know
I just bought something fro fellow Avcommer and I can see he struggled to remove double sided tape.
Get yourself some lighter fluid like Zippo, Rizzla, Ronson the cheapest, the liquid type and use it with cotton wool.
Squirt some some on, let it soak <2 min and rub with cottonwool.
It cleans it like a dream and it looks brandnew afterwards, it is paint safe, foam safe.
It leaves no oily residue or marks.
I even clean scuff marks from planes with it.
Any sticky labels, contact glue you name it.
I even clean plastic bowls from lables for my wife.
Enjoy
Francois Greeff (greeffbf)
"It's not what I wear or what I drive.... It's what I fly !!!"
doodapunisha
Reaching altitude
Closest Airfield: Boksburg Stadium
Re: Free Tip - maybe wrong forum
Unread post by doodapunisha » Fri May 24, 2013 4:18 pm
Thanks boet +1
Wickets
Closest Airfield: O. Tambo
Unread post by Wickets » Fri May 24, 2013 4:39 pm
I'll add to your tip, but I'll charge a cent for it. Now its in the right forum. For newbies like me, get a Flymentor. I have two, and would not be able to learn without it. (Nobody close by to teach me that I know of.)
I have a T-Rex pro and a KDS 450SV, both with Flymentors. While on the subject, is it possible to stabilize a flybarred heli with a 3G or 3GX unit?
kobusroux
Mags Dead Cut
Closest Airfield: Mpumalanga Int
Unread post by kobusroux » Fri May 24, 2013 5:48 pm
Goeie tip,ek gebruik Q20 dit werk ook baie goed ,haal teer van karre ook af. Kobus
Hennie vd Walt
Closest Airfield: Herderberg
Unread post by Hennie vd Walt » Fri May 24, 2013 5:56 pm
Ja dis n goeie idee Dankie man
Ek gebruik Johny Walker Red Label dis die goedkoopste een in die reeks en jy kan boonop n dop vat tusen in
Hennie vd Walt
0823603235
Francois Greeff
Hee Hee I'm Flying
Unread post by Francois Greeff » Fri May 24, 2013 6:07 pm
Wickets wrote:While on the subject, is it possible to stabilize a flybarred heli with a 3G or 3GX unit?
Yes, or can even just use the rudder channel, Same Allign 750 Gyro if you use the 3G from Align, also work great on scale 3/4/5 blade heads.
Francois Greeff
Hee Hee I'm Flying
Unread post by Francois Greeff » Fri May 24, 2013 6:10 pm
kobusroux wrote:Goeie tip,ek gebruik Q20 dit werk ook baie goed ,haal teer van karre ook af. Kobus
Ja, mr Min of Pledge werk ook maar vetterig.
jacquesnel1
Unread post by jacquesnel1 » Fri May 24, 2013 6:37 pm
Wat van cyano op canopies? Het n plane gekoop maar die canopy was geplak met cyano en het so n paar wit merke gelos.
Wickets
Unread post by Wickets » Fri May 24, 2013 6:39 pm
Kook olie werk ook, maar die Johnny Walker klink na 'n heel beter idee. Sal maar moet 'n paar liter kry. Weet nooit hoeveel mens dalk nodig het nie.
Francois Greeff
Hee Hee I'm Flying
Unread post by Francois Greeff » Fri May 24, 2013 6:52 pm
Wickets wrote:Kook olie werk ook, maar die Johnny Walker klink na 'n heel beter idee. Sal maar moet 'n paar liter kry. Weet nooit hoeveel mens dalk nodig het nie.
Moenie met jou kos speel nie, dis nou die Johnny Walker.
trewix
Paying Landing Fees
Closest Airfield: brakpan
Unread post by trewix » Fri May 24, 2013 7:32 pm
jacquesnel1 wrote:Wat van cyano op canopies? Het n plane gekoop maar die canopy was geplak met cyano en het so n paar wit merke gelos.
Rangsforafrica showed me to remove CA with nitromethane (the pure stuff, not mixed nitro fuel) - works really well!
Look out everyone - female pilot on the loose!
skytrooper
Has liked: 21 times
Been liked: 26 times
Unread post by skytrooper » Fri May 24, 2013 8:16 pm
i usually bite it off my fingers when i'ved glued myself.
Ubluwulululululu....!
Heliporn
Engine Started
Unread post by Heliporn » Fri May 24, 2013 10:58 pm
No dudes what I find works best is peanut butter (the smooth kind), the tears of a tibetan yak and the gravitational pull of the moon. Gets the gunk off everytime :smt023
clivem
Closest Airfield: howick
Unread post by clivem » Fri May 24, 2013 11:25 pm
+1 Nitro, works a treat on cyano
Save a plane - Fly FUTABA !!!
http://www.cmchobbies.co.za
Woema
Closest Airfield: Aerobatic Boys.
Unread post by Woema » Sat May 25, 2013 4:59 am
Carbcleaner for doublesided tape.
F16 Jet, Liberty Jet, H9 Beast, H9 Extra 100cc, 80cc J3 Cub, Trex 800, Trex 500, Trex 600, 550 flamewheel, mavic pro, Phantom3, Gliders, Funfly's .......
