Storing Heli's close to HTH
danie.e
Closest Airfield: Henley
Been liked: 20 times
Unread post by danie.e » Wed May 29, 2013 8:33 am
I wanted to do a deal with two Raptor heli's with a fellow AVCOM member but to my dismay found that my resident "soil engineer" failed to replace the lid of the 50kg drum of HTH for the pool in the same store room. As I have not flown the helis for a few months, they were left in the store room.
All metal parts of two helis that I wanted to swop was badly corroded - they are ruined
As a matter of fact, just about every metal object in the store room was corroded to various degrees.
Moral: Do not store heli's in the same place as HTH.
Reminder - never store HTH and Pool acid in the same place in case of an accident where the two can be mixed. It can result in a spectacular explosion.
Danie.e
S.A. Agent for ASP Engines, CY Models, King Max servos and Amass servo leads. Reseller of RCGF Petrol engines, Smartfly powerboxes, SkyRC Chargers and Power Supplies - http://www.aspaviation.co.za
TimB
Re: Storing Heli's close to HTH
Unread post by TimB » Wed May 29, 2013 4:02 pm
This fred is usefless without pictures and demo videos...
SteveJay
Closest Airfield: FASK
Has liked: 28 times
Unread post by SteveJay » Fri May 31, 2013 3:45 pm
Good post, thanks for the reminder.
I had a similar experience with the so called "spirit of salts". Good stuff to clean stained porcelain (Wash basins, toilettes etc.), but I never realized that it was a potent acid (HCl?). Two weeks in the workshop (in its closed container) caused serious 10-100 with metal, including my milling machine.
pipj
Closest Airfield: Rustenburg
Unread post by pipj » Tue Jun 04, 2013 5:16 pm
TimB wrote:This fred is usefless without pictures and demo videos...
I have to agree WE NEED PICS :D
Blade MSR
Hirobo Shuttle ZX
9 Eagles Micro Extra 300
Still learning to fly :)
skytrooper
Has liked: 21 times
Been liked: 26 times
Unread post by skytrooper » Thu Jun 16, 2016 1:38 pm
Ubluwulululululu....!
Trex600
Unread post by Trex600 » Wed Oct 09, 2019 2:12 pm
As far as I know "spirit of salts" is another name for Hydrochloric acid..... =D> =D> SteveJay you can close that container but it seems to find it's way out to destroy all your steel and aluminium parts. Also battery acid (Contains Sulfuric Acid). Sulfuric acid also known as vitriol. Must be kept out of your workshop and store room where metal is kept. Just a tip, if you have a servants toilet make a self in there and store it there this will save you mega frustrations. =D> =D> =D> =D> :D :D
Align Trex600's, Nitro, O.S.Max, Petrol Motor's Only DLE 30-55-111-120, Mintor38cc. Gold Wing 100cc Edge 540T, 100% JR XG11, No Contest,No Regrets. Build,Fly,Have fun.
