YAK ADF
The Yak Aircraft Corporation (formerly the A.S. Yakovlev Design Bureau JSC) is a Russian aircraft designer and manufacturer.
paulw
Closest Airfield: Kitty Hawk
Has thanked: 198 times
Been thanked: 82 times
YAK ADF
Unread post by paulw »
Hi
I found some info how to use the ADF in the YAK, but not really been able to try it yet as it is also rather difficult to set the frequencies.
(As far as I can see only ADF, not VOR)
Anyone know if it will work in SA?
I can't see why not.
.4 more years -soon
Don't believe what I post, research what I post
“We can only spread our knowledge outwards from individual to individual, generation after generation. In the face of the Thought Police, there is no other way.” George Orwell, 1984
Darrell Lush
Been thanked: 3 times
Re: YAK ADF
Unread post by Darrell Lush »
The Yak Nav avionics require some calibration before use. There is an ADF, a radio compass and a slaved RMI in most. You also need to set the RMI to the southern hemisphere. My one was working fine but I also have found it difficult to set frequencies. My ADF needle does track sometimes, but what exactly is beyond me. Is it possible for you to send me the info you have on the ADF. If the document is not too large you can post the link here on Avcom.
Thanks.
paulw
Re: YAK ADF
Darrell Lush wrote:The Yak Nav avionics require some calibration before use. There is an ADF, a radio compass and a slaved RMI in most. You also need to set the RMI to the southern hemisphere. My one was working fine but I also have found it difficult to set frequencies. My ADF needle does track sometimes, but what exactly is beyond me. Is it possible for you to send me the info you have on the ADF. If the document is not too large you can post the link here on Avcom.
Here some info I managed to get.
adf.doc
YAK52-handbook.pdf
.4 more years -soon
ZUBSK
Has thanked: 5 times
Been thanked: 1 time
Re: YAK ADF
Unread post by ZUBSK »
adf.doc
YAK52-handbook.pdf
As far as I remember, there are only three pre-set ADF frequencies. Had something to do with stopping russian pilots from defecting?? Talk to Vladimir, he will know.
Gary
Return to “Yak”
