Hi
I have been searching for Weight and Balance calculators/spreadsheets, but couldn't find any of real use.
They all seem to measure their CG, etc from different points like the jack point under the firewall where CXK is from the cowling rim at the front.
So I don't know if I go and measure it myself if it will be accurate.
Anyone with a YAK-52 with CG measured from the front who could share the calculators? Also other performance charts, etc which may be useful?
Thanks in advance....
YAK-52 W&B and other calculations
- Fife Thousand feet
- Closest Airfield: Kitty Hawk
- Has thanked: 198 times
- Been thanked: 82 times
.4 more years -soon
Don't believe what I post, research what I post
“We can only spread our knowledge outwards from individual to individual, generation after generation. In the face of the Thought Police, there is no other way.” George Orwell, 1984
.4 more years -soon
- 10000 and still climbing
- Closest Airfield: FABB
- Been thanked: 3 times
Re: YAK-52 W&B and other calculations
The Russians work on % of MAC. You should have sufficient information in your PoH to insert these into EasyPlan for example to give you a nice workable envelope/calculation. The chances are you will never het the CoG wrong on a 52 as you have limited space to pack heavy objects. A grossly overweight passenger will also in all likelihood not be able to squeeze into the cockpit anyway.
- Frequent AvComer
- Has thanked: 1 time
- Been thanked: 165 times
Front seat - pilot less than 95 kgpaulw wrote:Hi
Aft seat - girlfiend happy to go inverted
Shelf behind girlfriend- overnight bag conform and tooth brush.
More you can not load into Yak
