Manifold Pressure at idle
The Yak Aircraft Corporation (formerly the A.S. Yakovlev Design Bureau JSC) is a Russian aircraft designer and manufacturer.
Darrell Lush
Been thanked: 3 times
Unread post by Darrell Lush »
Had a bit of a brain fart today. I haven't flown my Yak for some time now so I thought I'd take it for a spin. I do not remember ever seen the MP below 20 cm at idle and only up to 40 cm at 70%. So I did a take off roll to monitor the MP and lo and behold she went right up to 80 cm as I am used to. Taxied back to the holding point and did a short flight. At cruise, came back to 70 cm no problem.
What MP reading do you guys get at idle ? ie 42%
paulw
Closest Airfield: Kitty Hawk
Has thanked: 198 times
Been thanked: 82 times
Re: Manifold Pressure at idle
Unread post by paulw »
Darrell Lush wrote:Had a bit of a brain fart today. I haven't flown my Yak for some time now so I thought I'd take it for a spin. I do not remember ever seen the MP below 20 cm at idle and only up to 40 cm at 70%. So I did a take off roll to monitor the MP and lo and behold she went right up to 80 cm as I am used to. Taxied back to the holding point and did a short flight. At cruise, came back to 70 cm no problem.
Hi Darrell
I had a look this morning as I didn't know and didn't want to comment earlier.
What I saw on CXK.
During Run-up at Holding point: approx 60cm at 70%. I think just a little less.
I don't remember during flight, but I think also in the region of 70 at 100% and then just after take off coming back to 82% RPM, the pressure dropped to about 47 as you also go back on the throttle. I am not 100% sure though.
However, when doing the "run-up" after flight before shutdown (64% for 30sec and 43% for 15sec), I checked the manifold pressure specifically as you raised this.
Pitch full fine, throttle At 32% approx bottom of quage 30 and popping below even but coming up to 32cm
Throttle to 28% or so showed an increase to actually about 32-34cm
Going 64% raised manifold presure to about 40cm.
I did this 2-3 times and was the same everytime.
.4 more years -soon
Don't believe what I post, research what I post
“We can only spread our knowledge outwards from individual to individual, generation after generation. In the face of the Thought Police, there is no other way.” George Orwell, 1984
Darrell Lush
Thanks Paul. You should get around 80 cm at 100%. I normally fly at 70cm/70% or 65cm/65%......keep it square. Up here in JHB you most likely will not be able to over-boost
Return to “Yak”
