The Dangers of RC aircraft
Hennie vd Walt
Closest Airfield: Herderberg
Unread post by Hennie vd Walt » Sun Aug 11, 2013 8:13 pm
call it stupidity call me a diekhead call it what you want, we all make mistakes
I wanted to start my 111 sbach this afternoon all by myself with no help ...big mistake
she flew with the working stand into my hand
I made a stupid mistake the throttle was open just to much
this engine has so much power
be carefull guys .....and like I always say no pain no gain..................... :oops: :oops: :oops:
Last edited by Hennie vd Walt on Tue Aug 13, 2013 6:31 pm, edited 1 time in total.
Hennie vd Walt
0823603235
Craigb
Closest Airfield: Elko
Re: The Dangers of RC aircraft
Unread post by Craigb » Sun Aug 11, 2013 8:26 pm
Ouch!
LAD
Tripped over wheel chock
Closest Airfield: Howick Kzn FAHC
Unread post by LAD » Sun Aug 11, 2013 8:27 pm
Thanks for the advice! Looks bad but you are lucky. Could have been a lot worse. I had something simliar when my electric 40 size ultra stick started up and cut my leg badly due to the fail safe set to max throttle by default on an orange Futabe compatible RX . These RX's are so easy to set so SET THE FAIL SAFE TOO!!! [-X
When everything seems to be going against you, remember that an aeroplane takes off against the wind, not with it.
henlo
Taxiing
Unread post by henlo » Sun Aug 11, 2013 8:31 pm
Sometimes we forget the basics - and that happens so fast! It could have been MUCH worse! My Multirotor attacked me the other day - also didn't do the basics... :-(
Hope you get well soon!
Hennie vd Walt
Unread post by Hennie vd Walt » Sun Aug 11, 2013 8:42 pm
eina hope you are OK
yes it happens so quick and when you don't expect it to
we all need to be more careful these toys are dangerous
Hennie vd Walt
0823603235
Hennie vd Walt
Unread post by Hennie vd Walt » Mon Aug 12, 2013 2:33 pm
I was lucky someone else just sent me a photo of a guy who's whole front of the finger is off
Hennie vd Walt
0823603235
Hennie vd Walt
Unread post by Hennie vd Walt » Mon Aug 12, 2013 7:32 pm
I just want to thank all the guy's who replied here and those who called and sent sms's
Thanks Guy's yip its scary and it could have been much worse, I hope i get over the shock quickly and swing the new prop soon :lol:
I've always been extra careful obviously not enough when swinging these big ones 50 and up
Hennie vd Walt
0823603235
Hennie vd Walt
Unread post by Hennie vd Walt » Tue Aug 13, 2013 7:37 pm
day 3 looking better already the small finger was cut through 2/3 's
Hennie vd Walt
0823603235
Hennie vd Walt
Unread post by Hennie vd Walt » Tue Aug 13, 2013 7:38 pm
the finger moves today jipee =D> =D> =D>
Hennie vd Walt
0823603235
Hennie vd Walt
Unread post by Hennie vd Walt » Tue Aug 13, 2013 7:58 pm
so kom dit nou met n klomp sms'e en n moewiese ge praat toe vra ek vanaand n mede pilot en friend as ek nou die nuwe prop optel vrydag of hy dit vir my sal swaai
ek meen my vinger is half af, hy se toe nooit not n flok swaai hy die prop nie.
nou wat staan ek te doen ..kry ek toe n beflokte idee ek hou vrydag aand n bring n tjop en swaai n prop by my huis :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Hennie vd Walt
0823603235
Hennie vd Walt
Unread post by Hennie vd Walt » Wed Aug 14, 2013 8:24 pm
nou wie gaan die prop swaai ?
chicken of wat ?
Hennie vd Walt
0823603235
Hennie vd Walt
Unread post by Hennie vd Walt » Thu Aug 22, 2013 7:52 pm
11 days later it's not doing as good as I hoped but the finger can move its been very painful and the healing is slow but it's getting there
Hennie vd Walt
0823603235
cabeng
Closest Airfield: Rotorua -NZRO
Unread post by cabeng » Tue Aug 27, 2013 9:21 am
Hennie vd Walt wrote:11 days later it's not doing as good as I hoped but the finger can move its been very painful and the healing is slow but it's getting there
Good luck , soon it will be a distant memory , with utmost respect for models :shock:
Clearly Weekends are made in china . They simply dont last !
Hennie vd Walt
Unread post by Hennie vd Walt » Wed Sep 11, 2013 7:55 pm
one month later ...........
almost ready ...... =P~ =P~ =P~
Hennie vd Walt
0823603235
Edge_Flyer
Forgot to remove the chocks!
Closest Airfield: Wonderboom
Unread post by Edge_Flyer » Fri Sep 20, 2013 11:48 am
Hi Hennie
Bly om te sien die hand doen beter. Het jy nou al die groot meneer gevlieg?
Groete
Evandré
