Cubby Project-Rebuild
A 75% replica of the original J-3 Piper cub.
stefan
Closest Airfield: FARA
Has thanked: 35 times
Been thanked: 170 times
Re: Cubby Project-Rebuild
Unread post by stefan »
Thanks. Any other ideas. Where did you install the IGN key and switches? Maybe some interior pics if you have.
wynvlieg
Closest Airfield: New Tempe - Bloemfontein
Been thanked: 1 time
Unread post by wynvlieg »
DWY panel
Sharing the passion of flying,
The Commander is my wanne-be aircraft!!
stefan
Thanks. Do you perhaps have a pic taken further away of the 2 top panels so I can see there placement?
Thanks
wynvlieg
Top panel
stefan
Thanks, that helps.
stefan
Man, this project turned into a complete rebuild. The previous guy never dry fitted anything before he covered anything so we had to take the ailerons apart, modify them and recover. So whoever buys this cubby will have a brand spanking new aircraft.
Jean Crous
Closest Airfield: FASX
Has thanked: 1235 times
Been thanked: 445 times
Unread post by Jean Crous »
:twisted: :twisted: :lol: Nou is julle sommer eerste klas Cubby bouers !!
On a more serious note.....Stefan you guys really do neat work =D> =D> I hope the price it will sell for, will do justice to your effort 8)
J
Cubby Aircraft Factory.
Cell : 072 6716 240
SACAA Approved Person 402
HansH2
Post Take off checks
Closest Airfield: Margate
Unread post by HansH2 »
What is dry fitted?
Jean Crous
HansH2 wrote:What is dry fitted?
That is when one fits the ailerons to the wing before covering both, to see if all hinge joints line up and check control connections and travel. Likewise fitting the tail-group in the same way for hinge alignment and control travel , stop to stop. Any alterations can then be made without spoiling a good fabric and paint job...........and frustrating the heebies out of the builder :lol:
Jean.
Cell : 072 6716 240
HansH2
Thanks for the info Jean
Jean Crous
HansH2 wrote:Thanks for the info Jean
Most welcome Hans !
J
Cell : 072 6716 240
Shumba
Preflighting
Closest Airfield: FANY
Unread post by Shumba »
Hello Stefan.
Ek verstaan jy het probleme gehad om die ailerons van die Cubby te pas. Jy is welkom om my te bel en te vra wat ek gedoen het om dit reg te kry. Dis te verstane dat jy nie alles van die Cubby gaan weet nie en net soos vir my, is dit ook vir jou n' leerskool in sekere opsigte. Ek het die ailerons, eintlik die hele vliegraam, droog gepas en opgemeet voor die oortrekproses begin is en alles het goed gepas. In die houer met boutjies ens sal jy sien is daar nylon wasters wat in die skarniere van die ailerons pas om te keer dat die metaal direk op mekaar skarnier. Hulle is omtrent drie mm dik. Sou jy hulle nie installeer nie gaan apsoluut niks pas nie. Nie dat dit nou meer saakmaak nie, want ek sien jy het die ailerons oorgebou. Hoop nie jy vind uit dit was onnodig nie. Die Cubby lyk goed so op die fotos, en jy is reg, dit is n' totaal nuwe vliegtuig.
Seenwense.
Jean Crous
When will this one fly again ?
J
Cell : 072 6716 240
PilotScrooge
Preflighting
Closest Airfield: FAPS
Has thanked: 13 times
Been thanked: 10 times
Unread post by PilotScrooge »
And so ZU-EUP has found its way into my hands. It has not flown for a very long time. The VW engine has been removed and replaces with a 582 Rotax after quite a few problems and failures. The change was still in progress when the aircraft was hangared and remained there untill I dug it out.
I aim to get her flying asap.
These users thanked the author PilotScrooge for the post:
Jean Crous
If flying was a language, gliding would be its poetry.
If you wanna race, switch off your engine.
Return to “Cubby”
