Oil pressure is spot on. Read the SL about the oil pressure and the spring replacement, yours now have the new one installed. Bearings happy all the way down to 1 bar
Oil temp normally runs a bit high after a rebuild, keep an eye on it, and use a higher speed and a bit of a lower power setting on the climb outs to control this.
I cruise climb at 95kts indicated in the summer. You want the temps just over 100 in the climb and just under 100 in the cruise.
Definitely rich looking at the EGT's and the Fuel flow.
Well done.
