Electronic Fuel Injection
checkride
Been thanked: 1 time
Re: Electronic Fuel Injection
Unread post by checkride »
Today decided to fit and weld on the Injector Bosses for the new engine. Monday will cadmium plate the intakes and fit to the motor.
johannstock
Closest Airfield: Witbank
Has thanked: 1 time
Unread post by johannstock »
Hi checkride where did you get the injector bosses? I am also looking at installing fuel injection on 2200 engine.
Thanks
checkride
[quote="johannstock"]Hi checkride where did you get the injector bosses? I am also looking at installing fuel injection on 2200 engine.
Thanks[/quote]
I supply them, in fact everything needed for EFI I supply. Call me. 0827838243
jetjr
Unread post by jetjr »
Any updates on this fadec setup?
lessersg
Post Take off checks
Closest Airfield: Cape Town
Been thanked: 7 times
Unread post by lessersg »
Not on this Engine, has since been sold. Will be doing a Rotax 914 and 912 ULS very soon will continue this thread . Autronic ECU, EdgePerformace Fuel Injection, Big Bore and performance CAM. :D :D
Some eye candy.....
lessersg
More candy....Lets hope my result turns out something like this. :D :D I'm doing the 914 converted to EFI. 125HP, with CSU. Then going to do a 912 ULS big bore , EFI and performance CAM- non turbo 120 HP.
Has thanked: 60 times
Been thanked: 1093 times
Unread post by heisan »
Looks quite good - but you have to ask yourself why Rotax redesigned the entire core engine for the 135hp 915...
lessersg
I have no clue and neither am I interested in the 915 :lol: as i know what they went through in testing and designing the upgrades for the 912 and 914 . The development of these upgrades have been tested and tested over and over again in some extreme conditions. The 915 is still in the infant stages but I speak under correction.
912 STI 158 HP engines running on some heavy Lift Gyro exceeding 1500 hrs and more. I think they are being used on some military machines, camera sensor ships ect.
Some have been stripped down every 500hrs , no issues yet. :D
lessersg
heisan wrote:Looks quite good - but you have to ask yourself why Rotax redesigned the entire core engine for the 135hp 915...
Maybe they needed more power and didnt know how to do it :lol: :lol:
lessersg
On its way Fun and Games...
lessersg
So its been a while ....and its done. See attached . If anyone is interested in more information drop me a PM.
lessersg
So the plane has been flying for about a year now . In this time we have made some changes to the cowlings, firewall forward layout and a lot of testing and flying.
We did a good few hrs taff testing....you know the wool and airflow thingy. Have video but cannot upload here. Basically as far as the cowl is concerned we had to reduce the airflow going into the cowl by at least 2/3rd. What was happening and why we were having a cooling issue is that the cowl was being pressurised. As we started reducing the airflow into the cowl the temps started dropping by at least 30c . This was oil and coolant. Now we have a very happy Turbo charged engine with Intercooler. Aircraft lost 6 kg on the nose in total even with the small changes to the cowling.
lessersg
So now that mechanically she is perfect, last part of this whole project is re-molding the cowl to remove the front chin. Inspection hatch on top for water and oil. So we will have a mold at the end of this and a Jig for the engine mount. Happy days for out J 400.
lessersg
That's now two done in SA both with Rotax 914....
lessersg
More flying with our Happy Jab...nearly 100 hrs now . We did 4 .5 yesterday some was climb testing again, making some small adjustments to the cowlings. But she is happy up high, low down , slow, fast etc. Have to calibrate Fuel computer and AFR sensor..... :D :D New molds for cowl soon, then respray....feel free to comment if you like LOL...
These users thanked the author lessersg for the post:
