Stickers...
Peter Connan
Closest Airfield: ORTambo
Has liked: 246 times
Been liked: 36 times
Stickers...
Unread post by Peter Connan » Wed Oct 15, 2014 8:24 pm
At the float-fly held in Springs last weekend, there was only one "real" crash.
The plane in question was flying quite nicely until suddenly something went audibly wrong. It became uncontrollable and hit the ground about 3m from some kids fishing from the shore of the dam.
This is what I think happened:
This picture was taken during this plane's previous flight:
A large sticker on the wing tore loose. Fortunately, it did not really seem to make much difference to the plane's flight.
But on the second flight, another sticker came loose:
Zooming in:
I think this sticker peeled back and buggered the elevator control...
I may be wrong here, but I just think this is something wort looking out for.
Nikon D500. 500mm f4, 24-120mm f4, 105mm f4 micro, 55mm f2.8 micro, Tamron 15-30mm f2.8
danie.e
Closest Airfield: Henley
Re: Stickers...
Unread post by danie.e » Tue Oct 21, 2014 10:25 am
With the covering coming loose during the flight, it should have been taken home for normal and proper maintenance. It can be clearly seen on the first photo that the covering on the elevator was coming loose as well. The owner should either have peeled off that part of the covering or he should not have flown the model again.
Danie.e
S.A. Agent for ASP Engines, CY Models, King Max servos and Amass servo leads. Reseller of RCGF Petrol engines, Smartfly powerboxes, SkyRC Chargers and Power Supplies - http://www.aspaviation.co.za
julway
Closest Airfield: Manzini
Re: Stickers...
Unread post by julway » Fri Jan 16, 2015 3:03 pm
Hi All.
I used to do most of the maidens at our club for the local gents. I was asked to do a test flight on a extra 300 .120 size, I did the standard maiden full check on the plane, we ran a 1/2 tank through it, ( motor was not new and well know as reliable.)
I took of and checked the trims etc. inverted, knife edge, dive, climb.
Anyway all went OK, I handed over to the owner and watched the rest of a very lazy and relaxed flight at the end I landed for him and we did a post flight check. This showed nothing out of the ordinary. ( I even did the shake test to check nothing was rattling around out of sight.
The owner fueled up and I took off again for him, as I was about to hand over there was a big bang and parts flew off the plane, I though it was a midair with a bird that's how violent it was, I just managed to put the plane down without further damage. ( pucker factor was very high.)
The problem turned out to be the balsa laminated onto the top of foam wing had almost NO glue on it, basically being held on by the covering where they overlap.
Now I make sure everyone is aware when there is a maiden taking place.
A friend who had a problem with covering and ignored it on one of his speed ships, had the covering come off the wing and jam the aileron and elevator.
To this day, I don't know how it went though the flight line and car park without hitting someone or something.
I have seen some incidents where they could have been avoided if the common sense rule was used.
The more common sense used, the less common the accidents.
My 2 Cents. enjoy the weekend.
Wayne.
He was wrong, the weight of an object is directly proportional to distance object is carried.
There is no such thing as Science fiction, it's just a matter of time.
Nothing runs on electricity it runs on smoke let the smoke out and it don't work no more.
