Introduction
South African Bat Hawk has been designed and developed by Micro Aviation South Africa primarily for surveillance and is the most affordable light sport aircraft on the market.
Micro Aviation
Fuelling up
Closest Airfield: Bat Hawk City
Introduction
Unread post by Micro Aviation »
:D Finally active on Avcom!
Micro Aviation SA is proud to announce that we now have SA CAA type acceptance for our locally produced Bat Hawk.
We have a fully equipped AMO at the factory in Nelspruit including engine overhaul facilities, specialising in Jabiru as well as CAMit engines for which we are the agents in SA.
Micro Aviation APs will travel if needed and we can service, repair and maintain your NTCA at your field if required.
Please direct any enquiries to info at bathawk.co.za
Micro Aviation
Fuelling up
Re: Introduction
Here is our latest delivery:
ZU-IDJ, CAMit powered Bat Hawk.
Ferried from Bantamcity to Uitenhage over 2 days.
She will be used by The Wilderness Foundation wildlife for conservation work in the Eastern Cape.
rudolphschar
Closest Airfield: Worcester
Has thanked: 200 times
Been thanked: 138 times
Re: Introduction
Unread post by rudolphschar »
Hi
What do these planes go for and how are they as light sport aircraft? How would they be for the weekend warrior who just like to go away for a weekend with his wife on a trip somewhere? Is there space for some luggage?
Rudolph
Rudolph Scharneck
The problem is not the problem, the problem is your attitude about the problem.
Mogas
Flaps set for Take off
Has thanked: 1 time
Been thanked: 6 times
Re: Introduction
Unread post by Mogas »
Rudolf
All the information you seek can be found at www.bathawk.co.za
:D
Sippin mogas
Return to “Bat Hawk”
