C150 prop
Zak
Mags Dead Cut
Closest Airfield: Eagle Creek
C150 prop
Unread post by Zak » Tue Jan 06, 2015 9:34 am
All the Cessna 150 owners with the O-200 engine.
Can you please give me a bit of advice on what prop, length and pitch, you turn, and what is the max rpm you get.
I believe the standard McCauley is a 69x50. What do you guys use that works well?
I only get about 2500 rpm, balls to the wall, with the 69x50 I have.
Taylorcraft BC-12D ZS-VHL
gerhardsteenkamp
Re: C150 prop
Unread post by gerhardsteenkamp » Fri Jan 30, 2015 7:17 pm
Zak,
Here is a link to the TDS of the C150. Listed is the apprved engines/props for different models, not completely on topic, but you might get problems if you install the wrong prop for the wrong motor. Have experience in this field with someone I know had the same issues.
Gerhard Steenkamp
The sky is not the limit, it's just another playground
CPL(A) ME/IR, Tow Rating, Tailwheel- and Turbine Endorsed
C150, C172, PA28(140-181), TC-06,TC-07, C82R, C182, C72R, DV20, SR20, BE55, T210, P32T, C42, PA32, C206, SF25, JAB4, JAB2, JAB1, C208
geraldp
Tripped over wheel chock
Re: C150 prop
Unread post by geraldp » Tue Feb 21, 2017 4:38 pm
Hi Zak,
I had a similar problem with my C150 and could not get more than 2450 rpm on take off run until it was discovered that the prop was in the wrong position - ie the prop was in front of the air filter on the induction stroke. The prop was rotated 30 degrees and bingo - gave me 2550rpm. You can speak to Gary at Aero Natal, Virginia Airport, Durban. He discovered the problem.
Return to “Cessna”
