Hello World - I am ZU-JRV
Jan
Closest Airfield: MOSSELBAAI
Has thanked: 94 times
Been thanked: 159 times
Re: Hello World - I am ZU-JRV
Unread post by Jan »
I have also installed the flap actuator and positioner - this was purchased from The Peregrine as he used a VPX.
See viewtopic.php?f=64&t=133251#p1426936
As usual Rikus always gets involved in Oupa's adventures and is a keen helper.
Flying is about discipline!
AP325
RudiGreyling
Closest Airfield: The Coves
Has thanked: 120 times
Been thanked: 203 times
Unread post by RudiGreyling »
Jy moet Rikus leer om in die stert rond te kruip en werkies daar te kan doen, lyk of hy lekker daar kan inpas, dan sal ek hom by jou kom huur per uur as ek weer in die stert moet rondkruip. :D
Kit Builder
RV-7: viewtopic.php?t=3239
RV-10: viewtopic.php?t=48930
RV12 Group Build: viewtopic.php?t=59137
Jan
Ek het n idee sy fooi sal nogal hoog wees :D
AP325
Jan
Moving forward - the roll bar is on and the forward top skin also clecoed in place for the first time.
AP325
Jan
I have been a bit slow on this project the last two weeks. No less than 3 AC to do Annual Inspections on. :oops:
I have started however to populate the Firewall. First had to build the battery box. Note that I still have not riveted the Firewall Recess as I need access there when doing the canopy.
AP325
DDO
Closest Airfield: Piet Retief Firebase
Has thanked: 4 times
Been thanked: 14 times
Unread post by DDO »
Looking good !
Concerning the flap positioner, where do you feed is to, and what advantage is there
in having accurate flap position indication ?
Jan
The positioner in this case is the one from Vans that stops the flaps in 3 positions on the 6/7/8/9. This is 0, 15 and 30 degrees.
So if you are at 0 flaps, you just flick the DOWN switch and it will move to 15 degrees and stop. Flick it again and it will go to 30 degrees and stop. The down part of hte switch is momentary. The when you need to go flaps up, you just put the swith in the UP position and it will go up and stop at 0 degrees.
So in this case it is not a sensor that you can connect to an indicator, but just an auto stop at certain points.
You can add various resistive position sensors and feed it to a number of indicators. Skyview will also indicate it.
Hope it helps?
AP325
DDO
Thank you for the explanation.
Jan
A nice milestone is when the Forward Top Skin is riveted on for keeps. It also marked the 200hrs mark of this project.
AP325
Jan
A lot of small jobs done and also the BIG CUT done.
AP325
cvdw
Closest Airfield: Wonderboom
Unread post by cvdw »
Ok Jan, now how about a real panel pic!? :lol:
Jan
Ok - here is a cad screen shot of what it will look like.
AP325
Jan
Engine mount is also installed now.
AP325
Jan
The engine hanging ceremony took place.
AP325
BigglesSA
Has thanked: 79 times
Been thanked: 17 times
Unread post by BigglesSA »
Jan jy vorder mooi. Dankie weereens vir jou tyd Saterdag asook die RV grin na 'n onverwagte flip in Stumela!
Ek grin nou nog!!! :D 8) :D
Groetnis
Francois Gouws
